05-29-2020, 12:10 AM | #1 |
Rep 35
Will if Fit?
I have some 3 series e90 wheels I want to use on my 2016 528i xdrive for a winter set up. Will they fit? I know i will need different tires and TPMS sensors. Will it adversely affect the the drive train, traction control, or suspension? I understand 4mm is fairly small so it should be fine, right?
e90 Style 161 Size 17x8 ET 34 F10 style 452 Size 18x8 ET 30 |
05-30-2020, 07:48 PM | #2 | |
Rep 913
Im no wheel guru, but best thing you could try is see if the 17 clears the calipers. Do they have tires on them? Can always test fit since you have the wheels. I found a post about half a year ago he was selling Chevy impala wheels, they share the same 5x120 lug pattern, All i did was take mine off front and check clearance. |
05-31-2020, 09:52 PM | #3 |
Rep 35
Nice, I have them in storage so I will have to give them a fit. I assumed they would clear I just didn’t want to screw with the traction or stability control. Thanks for the reply.
