2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Is this a spring collapse?
      05-26-2021, 09:44 PM   #1
chip3130
Drives: 2013 BMW 535xi MSport
Was driving on the highway this past weekend and experienced a sharp dip (not a pothole)... once going over it i heard a BOOOOOF and thought i blown out a tire, pulled over to the shoulder and took a look and it looked like the rear driver side Spring collapsed... thoughts?
This seems pretty rare, but could be something else. My mechanic is taking a look at it this weekend to diagnose, obviously anxious, what do you think?
I do have H&R springs installed.
      05-26-2021, 10:23 PM   #2
Hoa
It does look like a spring related issue. Strut would not make it come that low and any arm will make the wheel bend a certain direction
      05-27-2021, 09:41 AM   #3
Unspec
Unspec's Avatar
Drives: 2015 BMW 535xi
Yup, your spring probably "slipped" down. At that point, your strut is likely blown as well.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      05-27-2021, 06:59 PM   #4
Blue Angel
Blue Angel's Avatar
Please post pics of the failure, it will be interesting to see what went wrong.
      06-15-2021, 10:09 AM   #5
Blue Angel
Blue Angel's Avatar
Any update on the failure?
      07-09-2021, 10:53 AM   #6
chip3130
Will post pics once Iím at a computer, but it was a knuckle collapse, completely stripped from the wheel hub. 😪
      07-09-2021, 11:50 AM   #7
Blue Angel
Blue Angel's Avatar
WAT?!? Wow, I can't wait to see pictures of this.
When you hit the sharp dip did the car bottom out? Were the bump-stops still installed on the shocks?
      07-17-2021, 01:43 PM   #8
Blue Angel
Blue Angel's Avatar
Did you ever get a chance to put those pics on your computer?
      07-17-2021, 02:01 PM   #9
musclesmarinara75
musclesmarinara75's Avatar
[QUOTE=chip3130;27634165]Was driving on the highway this past weekend and experienced a sharp dip (not a pothole)... once going over it i heard a BOOOOOF and thought i blown out a tire, pulled over to the shoulder and took a look and it looked like the rear driver side Spring collapsed... thoughts?
I do have H&R springs installed.[/
Is that College Point in Queens.. looks familiar
$ PURE STAGE 2 {} ER CATTED DP {} BM3 CUSTOM TUNE BY CAREY JORDAN {} DORCH HPFP {} ER CHARGEPIPES {} ER FMIC {} TMS CF INTAKE {} DINAN EXHAUST {} CARBON HOOD TRUNK LIP AND MIRRORS $
      07-18-2021, 08:43 PM   #10
chip3130
      07-18-2021, 08:45 PM   #11
chip3130
[QUOTE=musclesmarinara75;27814325]
lol, on my way back to Queens actually, this happened near Baychester, exit 13 on 95 south.
      07-18-2021, 08:48 PM   #12
chip3130
Shocks still good, and yes car bottomed out immediately. Was still able to move, didnít lose control but the wheel was pressed up against the body. Car was repaired, knuckle fixed with new wheel hub.
      07-19-2021, 01:27 PM   #13
Drives: 2014 535i M Sport
That sure looks like a blown shock to me. They should be dry and that one has significant moisture (at the top).
      07-19-2021, 11:09 PM   #14
Blue Angel
Blue Angel's Avatar
Ah, looks like the bolt that holds the shock to the knuckle broke off.
This is interesting. That bolt has a very high torque spec (it's apparently very hard to remove). I wonder if it was under-torqued when installed, leading to a fatigue failure?
I would consider having the bolt on the other side replaced, and having the torque on both sides verified. My $.02
      07-21-2021, 05:18 PM   #15
Unspec
Unspec's Avatar
Doesn't look like the bolt failed - looks like they were in the middle of disassembly when the photo was taken.
2015 BMW 535xi
      07-21-2021, 07:29 PM   #16
Blue Angel
Blue Angel's Avatar
chip3130, can you confirm if this is a pic of the failure, or during disassembly? If during disassembly can you confirm the point of failure (i.e. were there other failed components not shown in these pictures)?
      07-26-2021, 08:43 PM   #17
chip3130
Blue Angel is correct. This photo is of the car on lift for initial inspection. Bolt failed.
      07-26-2021, 09:08 PM   #18
Blue Angel
Blue Angel's Avatar
Thanks for clarifying!
Looks like that bolt is supposed to be torqued to 250 Nm (184 ft-lbs), assuming the member who posted the info is correct:
https://f10.5post.com/forums/showthread.php?t=1464505
Sounds about right. Since it's tough to get to I can see why someone might not take the time to torque it properly, which could lead to a fatigue failure. Scary stuff!
      07-26-2021, 10:44 PM   #19
Unspec
Unspec's Avatar
Can confirm that it is 250nm, and can confirm it's a bitch to get to. It took me 2 days to torque it to spec because I was so gassed after installing my coilovers and I needed rest. You need to take off the rear toe arm to get any realistic amount of swing on the torque wrench. You basically have to bench press the car if you don't have a lift lol
2015 BMW 535xi
      07-27-2021, 06:30 AM   #20
Blue Angel
Blue Angel's Avatar
Thanks for the advice! My coilovers just arrived so I'll be installing them soon.
Copyright ©2000 - 2021, vBulletin Solutions Inc.
