2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum fault codes on my 2010 f10 523i
      06-16-2021, 03:39 PM   #1
Vega2k
Drives: BMW F10 523i
Hi. I just got my self a f10 523i.
I have got Ista+ up and running and also E-sys but im very new to these softwares. Ive been previously familiar with Inpa, Winfkp and NCS when coding and diagnosing my e39.
i fired up ista and successfully connected to the car. it had alot of fault codes stored to it from before. I decided to save it and delete all fault codes, which now left me with 4 fault codes.
Fault code memory list, VIN: WBAFS11050C243517
ISTA system version: 4.29.15.23407
Int.lev.works: F010-10-01-502
Mileage: 94941 km
CODE:
FZD3 : 801A52 - SINE: fault when adjusting coding data
CIC : B7F809 - Connection head-unit to DAB III-band aerial foot: open circuit
CAS4_2 : 9307AF - Outside door-handle electronic module, driver's side, rear: non-permissible current value on unlock line
MSD87: S 0313 - No communication possible with: All-round vision camera
Now the CIC and CAS fault is not a concern at the moment, where as previous owner have had fitted an external dab+ module to the car
and most likley took the antenna from the original dab and as for the cas it seems to have an isssue with the comfort access not working on the driver side.
Now for the two other ones i do now know, ive been googling around but i can not find anything related to them.
and also read up on the troubleshooting guide for these but at the moment i can not figure it out.
But can these be related to each other?
There has been fitted an aftermarket Rear camera to this car and it works displaying, and was coded to the car by previous owners mechanic..
Also previous owner told me he was using e-sys himself to code lane assist to the car which he stated worked but i dont really know this for sure.. but he mentioned it did not shake the steering wheel as the car is not equipped with the system, so he removed it.
This is very new to me so if anyone knows about this or got a clue where i can start digging would be great.
Copyright ©2000 - 2021, vBulletin Solutions Inc.
