2010 2011 BMW 5 Series Forum F10 2011 550i (N63) Spark Plug DIY |
04-03-2021, 11:22 PM | #23 |
Rep 262
Just did plugs today and checked me last set and I actually was using .026. With my tune I decided to go with 0.022.
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
04-04-2021, 10:25 PM | #24 |
Cole
321
Rep 498
This really is a super straightforward change. Greta video and super helpful for anyone needing it, but as easy of a spark plug change as anyone could have.
I swap mine out at least every 15k and it couldnt take more than 1hr. I have my ngk 2 step colder plugs at .025 across the banks. Precisely adjusted and everything running perfectly smooth. In my experience, it is most important to install everything per torque specs and make sure your gaps are consistent across the banks. Run higher boost and drip the gap from .032(stock) to .022 I sit in the middle at 4psi boost increase and feel that .025 is a strong gap with ngk stage 2 as well as my mods. |
