2010 2011 BMW 5 Series Forum F10 Drivetrain Malfunction. Crankshaft-exhaust camshaft |
04-16-2021, 06:44 PM | #23 | |
Rep 262
Funny part of the story… I decided to hook up ISTA and what would know, intake coupler came loose between MAF and Turbo, 🤦🏽, yeah I know i still feel stupid b/c I was looking all around it. Reconnected it and all good. Not saying it's the same thing but it could be another fault though. I'm not sure why Carly didn't show it as a MAF/lean fault and I am not familiar with the tools you are using, but I would recommend trying ISTA and seeing what comes up. It may help clarify what the issue is. Now I am not saying I don't carry Carly in my car for immediate checks and clearing faults via phone and not having to lug around my PC, but whenever I have DTM again,🤞, I will only pull those faults with ISTA. Good luck with getting it fixed!
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
05-16-2021, 10:47 PM | #24 | |
Rep 1
05-29-2021, 01:03 PM | #25 | |
Rep 14
Hey I PMed you But it's also funny you mentioned that, because I'm a very cost efficient person. And I was trying for days to install ISTA on one of my laptops. Just so I won't have to buy a scanner lol But I keep getting start up error on it, which lead to me buying a scanner. I'm 32 & don't have the patience I once did younger lol. I would love to use ISTA to check things like if the chains are stretched etc Any tips or help on installing, pretty sure I followed all the steps. Clearly doing something wrong though |
05-29-2021, 01:11 PM | #26 | |
Rep 14
But best option would be to run ISTA to get a more direct diagnostic. Because the next 2 steps after, are either Vanos Gear/adjuster replacement or stretched timing chain |
05-29-2021, 04:24 PM | #27 | ||
Rep 262
2011 550i (N63)
06-01-2021, 08:39 PM | #28 | |
Rep 14
Come to find out, all I needed was to update to Windows 10. And ISTA started right up lol Going to run some scans & test the timing chains etc tonight, definitely need good luck Last edited by FlyNikolai; 06-01-2021 at 08:57 PM.. |
08-25-2021, 07:32 AM | #30 |
Rep 4
I think unless the engine block is cracked or the cylinder head is destroyed, replacing the engine is ridiculous. I believe that it is easy to do if you have professional lift, But I dont have and it is terrible to work under the car to remove something. Especially N63 engine is not easy to work while the engine is in the car. If I have proper lift to remove the engine, I rebuild it and put back to the car. Why should I buy engine ? I prefer to sell the car someone wants to work on it as project and buy another car. So far I am really exhausted with this problem but I will figure it out. Only problem is replacing the chain but I think I can do it too. Let me know if you find a solution or if you did find ? The post from April maybe you guys still have your bimmers and solved your problems.
08-27-2021, 07:46 AM | #31 | |
Rep 14
I fixed little things like the comfort access door handle, new pcv valves, upgraded all lights to LED etc. I'm a DIY guy so I can fix most things, except big jobs. I like to live luxurious...but for cheap 😂. Anyway to answer your question, I haven't gotten mine fixed yet. The BMW Master Tech, that's supposed to do the work for me. Had a ton of projects for the summer, so I'm just waiting until he's free. However using ISTA+, I've narrowed it down to the Exhaust Camshaft Adjustment Unit. I ran all the test in ISTA+, and the timing chains test passed & everything else is fine. The central bolt is probably loose, or the Adjustment Unit is bad I have a replacement unit & bolt, with copper paste in my trunk. Just patiently waiting for some amazing BMW Master Tech to fix it for me 😃 So I recommend running ISTA, the tests in there are really helpful. It does everything automatically for you. Also if you're having oil burn or smoking from exhaust Throw in a couple cans of Liqui Molly Motor Oil Saver, it'll stop the smoke. Cheers 🍻 Check out my interior https://twitter.com/Nikolai360W/stat...465632779?s=19 Last edited by FlyNikolai; 08-27-2021 at 07:56 AM.. |
