2010 2011 BMW 5 Series Forum F10 Engine Light Reset P0456 |
05-26-2021, 05:57 PM | #1 |
Rep 86
Went to start the 2013 535XI on Sunday morning and the engine light was on. I was out of town so I ended up driving it all day Sunday and Monday before I could get a code reader on it. Did a system check and everything was fine , so I was not perticularly worried.
Plugged in the code reader and get P0456. Problem with the EVAP. However, the code reader shows EVAP system, as well as all the others passes the readiness check. Tried to clear the code and it won't clear, or turn the light off. I'd like to clear the code and turn off the light to see if it comes back. It seems strange that there is an EVAP code, but the system readiness checks fine on the OBDII reader. What am I missing? I've never had a fault code in this car before. In my Land Rover I get one or more a month. Usually I just hit the clear button on the OBDII scanner and it clears the Rover. Is thee a trick with these F10's? |
06-07-2021, 04:28 PM | #3 | |
Rep 49
If you note what scanner you're using, maybe someone will be able to advise. |
06-09-2021, 03:03 PM | #4 |
Rep 77
Clearing Engine Check Light will most defiantly will bring it back, as its emission related code. The EVAP error code is most likely due to faulty DMTL (old known Purge Valve). It's located behind the rear passenger tire in the wheel well. To know for sure if that is the issue, you need to use BMW ISTA-D. If the issue is with DMTL, check with BMW Service Adviser as this part is covered by warranty beyond standard one up to a curtain mileage.
2013, 535 XDrive, 112k miles
1997, 328is, 335k miles - Retired 1998, ML320, 200k miles - Sold 2018, Q5, 100 miles 2005, XC70 AWD, 160k miles |
