2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Jb4 or ecu flash
      12-07-2018, 09:03 PM   #1
Hb_z
Drives: F02 750 2011
Jb4 or ecu flash
Hi guys i have a bmw with the n63 engine i installed a catless down pipe and im Im ging to tune it but what is the best for preformance . + how much are the gains the car currently has put down 360WHP
      12-07-2018, 11:33 PM   #2
jonobro
Drives: bmw f10 535i
Do you have a cp?
      12-08-2018, 12:42 AM   #3
Hb_z
No
      12-08-2018, 01:14 AM   #4
Hb_z
Do you have a cp?
No
      12-08-2018, 10:32 AM   #5
jonobro
Do you have a cp?
No
I have a cp not sure what to add next, not sure is adding a dp and a Cp would be to good
      12-08-2018, 10:57 AM   #6
Hb_z
Do you have a cp?
No
+what's a cp?
Is it a charge pipe because I don't know what that is
      12-08-2018, 11:05 AM   #7
Hb_z
Do you have a cp?
No
Can u take upload a pic of it
      12-08-2018, 11:17 AM   #8
jonobro
Do you have a cp?
No
Yes charge pipe
Hb_z0.00
      12-08-2018, 01:40 PM   #9
335xi Beast
335xi Beast's Avatar
Drives: 2014 White 550i
You need a charge pipe, down pipe is good, intercooler upgrade usually, and definitely go with a an ECU TUNE! I've had 3 JB4's on previous F30's and F10's and N55 engines. To me it was like kissing my sister. It's a cheap way to go but from my experience I finally listened to my tech.
My current N55, 335xi has now 370HP from 300 and 500 tq from 300. He said the exhaust set up contributed significantly to the output. I did have the CP, DP (catless) and straight pipe set up. Wagner intercooler as well. Hands down this is the most I've ever had with a tune. Keep in mind this is obviously just scratching the surface as a beginner. I only run 93.
The pull is continuous and constant which is a blast! It's well worth the money imo!
F10-550i //Alpine White//Vorsteiner VFF-107/Carbon Graphite// 245/35/20 +30 - 285/30/20 +45. STOCK
Hb_z0.00
      12-08-2018, 10:17 PM   #10
warpeacelove
Drives: 550i
Charge Pipe on the N63???
      12-08-2018, 11:04 PM   #11
ziekxq
Drives: 2011 535i xDrive
Who are you using to create your flash tune maps?
      12-09-2018, 07:21 AM   #12
335xi Beast
I used Frank Smiths shop Tuning Tech over in Crofton Md. I've said in previous posts even he had never gotten so much out of a basically stock car except of course the aforementioned bits I installed. Sure I could keep going to the limits but it was my daily driver at the time. I just wanted a fighting chance against an EVO.
PS. www.tuningtechfs.com
Hb_z0.00
      12-09-2018, 01:32 PM   #13
ziekxq
Thanks for this info... I am going pure stage 2 and sort of looking around to see what other members used for their flash tuning need.
      12-09-2018, 02:00 PM   #14
rhodius
Drives: F10 550i
I'm in the same boat as you. I have a 2012 550i with N63. Still looking to get improvements, all I want is a little more responsive and quicker acceleration.
I was looking at JB4, but someone suggested looking at activeautowerke. I looked at their website, it looks like the chip tune is only for N63TU or S63TU. Can someone correct me please?
      12-09-2018, 02:47 PM   #15
Hb_z
I'm new to bmw modification world
But in a couple of months I install a fabricated cai and tune it
      12-09-2018, 02:48 PM   #16
Hb_z
The smell of the catless downpipe is really bad
      12-09-2018, 04:03 PM   #17
ziekxq
QUOTE=Hb_z;24092518]The smell of the catless downpipe is really bad[/quote]
I dont even smell it anymore unless im standing behind the car.
The only thing about catless downpipe is that if i havent done any WOT runs in few days then I get that black smoke the next time I do WOT from 1st gear.
      12-09-2018, 10:58 PM   #18
byebyev8
Drives: 2007 335i coupe
Go jb4+Bcm or the bad black tune. Those seem to have the best results on the n63. Should easily be able to make 100whp more without any other mods. N63 doesn’t need an upgraded charge pipe or intercooler (m5 or alpine) to make 500+whp.
Tags
550, 750, downpipe, jb4, n63
