2010 2011 BMW 5 Series Forum F10 Battery Discharging Warning |
01-04-2024, 03:27 PM | #89 | |||
Rep 7,505
Have you had the battery tested? This will determine its state of charge or if it is holding a charge or not. If not, it could be due to age or a dead cell. Every time you've asked, you've been given suggestions & recommendations...but you never post back that you've done any of the things suggested. We don't know if the message will remain if you replace the battery if you've not checked if the problem is the battery, the penny stuck in your cig socket, or your door handles, etc. We are NOT there with you so can't say if any of these things are causing your issue. You have to determine or have someone diagnose the things suggested so that you can rule them out as the culprit. How old is your battery? Again, have it tested to see if it is holding a charge. What is it's state of charge? Is it below 11.2%
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
razfrankel3.00 |
01-04-2024, 04:15 PM | #90 |
Rep 55
Apologies but when I get my car inspected the beginning of next month and get do an oil change. I will check out the problem see what is the cause of the state of charge. I went to the mechanic when it happened the mechanic said I need a new battery. I got the pennies out Sunday it was 3 pennies. My dad told me not to mess with it.
01-04-2024, 05:37 PM | #91 | |
Rep 7,505
I embedded a direct link back in post #87 that discusses the current prices of the BMW b trended battery and aftermarket batteries. If you do the same…you may find that the BMW battery being sold by your local BMW dealership may be the better price if not it is usually priced competitively. And sometimes it has a higher amp hour (AH) rating…especially if you need thge larger 105 AH battery. Many aftermarket brands only have a 100 AH battery in the 95R/H9 class size. And if you need the slightly smaller 49/H8 battery…BMWs battery is a 92AH battery…and the aftermarket batteries can range from 90AH - 95 AH…and may cost a bit more. But you’ll only know this if you call around and do a price check in your local market. There’s also other tips to make sure you get the extra vent plug and little black elbow that connects the car’s vent tube to the battery. You will need these to prevent the off gasses from the battery not being able to escape to the exterior of the car. Hopefully you clicked the link so that you read all of this info so you’re informed. Good luck. And if you haven’t yet…GET THAT PENNY OUT OF YOUR CIG SOCKET!
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 01-04-2024 at 05:47 PM.. |
razfrankel3.00 |
