2010 2011 BMW 5 Series Forum F10 Replace small screen with big screen? |
07-29-2016, 09:12 AM | #1 |
Rep 35
Is it possible to replace the center console screen (GPS and what not) small screen with the large screen versions?
Is it DYI? What would the cost be? I've searched throughout the forums, but haven't found an answer. Thank you! |
06-02-2019, 09:44 AM | #4 |
Rep 4
I'm looking for coding instructions for this swap, I have the small CIC screen on my 2012 F10 and I bought the 10.25" screen.
Did you get any luck with your swap? |
11-04-2019, 12:39 PM | #5 | |
Rep 10
I also want to do it, could you inform me? |
06-05-2020, 07:39 PM | #8 |
Rep 14,522
Still waiting for people to chime in. I also have the 6" CIC screen and bn I've been seeing the 10" screens for less than a $100. Want to confirm if its straight plug n play?
06-06-2020, 02:55 PM | #9 |
Rep 418
As far as I know it requires coding to at least change screen resolution since 10.25" screen has higher resolution than 6". It may require additional coding for other things.
lsturbointeg9155.50 |
06-06-2020, 09:24 PM | #10 |
Rep 14,522
No other cables needed or components tho? I'm assuming if I just swap the screen without coding the picture will be stretched?
06-06-2020, 10:27 PM | #11 | |
Rep 5,362
edit: This? |
06-07-2020, 07:48 AM | #12 |
Rep 14,522
i'll check out the video bro. i'm not even sure i'll even get that display? sucks cuase there's not enough info out there to say what happens if you swap without coding or with? and specifically what coding needs to be done exactly. that video is also a touch screen so i don't know if the one's for less than $100 that i've seen have this capabilities?
06-07-2020, 01:29 PM | #13 | ||
Rep 418
Since 2011 F10s have CIC, you may consider NBT or NBT EVO upgrade. You may get them from used parts places or eBay |
06-07-2020, 02:05 PM | #14 | |
Rep 14,522
06-07-2020, 06:07 PM | #15 | |
Rep 418
Just a setup on an Android unit, post install. You should get Android 10 unit, that is the latest version. This is quick feature overview This is another style of Android head unit, different look, same features Last edited by dzz; 06-07-2020 at 09:37 PM.. |
