2010 2011 BMW 5 Series Forum F10 Should I replace headlights that aren't burnt out? |
09-14-2018, 11:09 AM | #1 |
Rep 638
so a question,
So I know that headlight bulbs deteriorate over time. is it worth replacing them if they have not blown after a certain period of time? Would it make a visible difference. If so after how many years of use? Anyone upgraded OEM lights to say LED, xenon, HID's etc etc and found it a worthwhile, cost effective Is it also more a case of these new fangled plastic lens going through UV light? MINE are fine at present, but I'm guessing, using lights all the time, you don't really see a difference. thanks |
09-20-2018, 07:33 AM | #2 |
Rep 2,527
If you have a halogen in reflector set up please don’t put HIDs in.
If you have HIDs / xenons the color eventually shifts towards the blue end of the spectrum and you’ll have diminished output but from what I gather they will last many many years. So if nothing wrong don’t change |
09-20-2018, 07:35 AM | #3 |
Rep 2,476
Drives: Satan's Chariot 2.0
If they are HIDs & you've noticed diminished output, change em. They don't last forever.
09-20-2018, 07:49 AM | #4 |
Rep 3,988
Halogens don't need to be replaced until they burn out.
A good quality HID bulb (Osram, Phillips, etc) would provide improved light output over an oem hid bulb. Beware of cheap HID bulbs, they will likely provide reduced output. Change them in pairs, esp when using different types of bulbs or the age of the bulbs vary widely. |
09-20-2018, 11:40 AM | #5 | |
Rep 2,476
09-20-2018, 11:49 AM | #6 |
Rep 640
Drives: 2008 M3 (E93)
