03-02-2017, 06:07 AM | #1 |
Rep 19
Aggressive Fitment 20"
Guys I need help with my wheels. I know there is many posts like this. But i didin't find anything that could help me. I want aggressive wheels. So my dealer is having this 20x9 et20 or et35 in front and at the back 20x10.5 et25 or et42. So what do you think 20x9 et 20 and 20x10.5 et 25 is it too aggressive?
03-02-2017, 06:40 AM | #2 | |
Rep 544
Project Gamma Intakes / Project Gamma Catless Downpipes / Muffler Delete / DME Stage II Tune / H&R Springs |
03-02-2017, 06:49 AM | #3 |
Rep 19
I now have 20x8,5 et35 in front and 20x9,5 et 45 at back and it's not aggressive at all.
03-02-2017, 07:01 AM | #4 | |
Rep 544
03-02-2017, 07:32 AM | #6 |
Rep 738
The front would be ok, but the rear is way too aggressive, I had a 20x10.5 +42 and it was pretty flush with a 295 tire on it, with a 285 tire I put a 3mm spacer to make it look better.
2011 550i
2013 M5 2014 M5 CP 2016 550i |
03-02-2017, 07:33 AM | #7 | |
Rep 19
03-02-2017, 07:45 AM | #8 | |
Rep 19
look at this offset 20x9 +18 and 20x10.5 +25 |
03-02-2017, 07:58 AM | #9 | ||
Rep 544
03-02-2017, 08:01 AM | #11 | ||
Rep 544
03-02-2017, 08:45 AM | #13 |
Rep 544
Yes
03-02-2017, 12:46 PM | #14 |
Rep 29,212
Do the ET42 in the rear, no question about it.
If your car was really low, I'd say ET20 in the front, but since it's at normal height, I'd say ET35, it's not aggressive, but you could add spacers.
03-02-2017, 05:58 PM | #15 |
Rep 14,521
i've got a pretty aggressive fitment on 21's. specs are front 21x9.5 30mm and rears are 21x11 38mm. currently sitting on KWV1's sitting pretty pretty LOW! this is just to give you a bit more perspective regarding my offsets.
for the fronts i probably could have run some spacers but being this low i did not want any rubbing due to the fact when the car's shocks compress over bumps and what not i think it would rub the fender and cut the tire's sidewall. the rear is pretty flush! i'm pretty sure with any more offset the tire would hit big time!
03-04-2017, 04:43 AM | #16 |
Rep 19
Is it possible to run at rear et25? And if its possible how much will it poke out? I'm on factory M suspension as you can see
03-04-2017, 04:48 AM | #17 |
Rep 19
03-04-2017, 04:50 AM | #18 | |
Rep 29,212
03-04-2017, 04:59 AM | #19 |
Rep 19
Sorry i don't know much about wheels. So it will be better if I add spacers? with +42 at rear. If anything means to you i'm buying veemann vc7 wheels. I want them to be concave, is that have anything with offset, it says that wheels are deep concave.
03-04-2017, 06:22 AM | #20 | |
Rep 29,212
Is the 20x10.5 ET42 deep concave, or only the 20x10.5 ET25?
03-04-2017, 06:38 AM | #21 | |
Rep 19
03-04-2017, 06:45 AM | #22 |
Rep 29,212
Mine are ET46, that equivalent to 20x10.5 ET40 if you look at the outside edge fitment.
