2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum 535ix M sport exhaust tips
      11-01-2022, 08:11 PM   #1
zvery777
zvery777's Avatar
Drives: 2021 M550
Hi everyone. I'm looking to replace the exhaust tips on my F10 and wanted to ask those who have done without having to do any modifications to the exhaust (want to keep it stock): is there a good seller/place that offers tips that fit without issues?
Dual or quad does not matter to me as long as they fit without issues.
Thank you!
      11-03-2022, 08:07 AM   #2
SWFLf10
SWFLf10's Avatar
Thank you!
I know the m performance mufflers have tips that are easily swappable via a set screw hidden on the bottom side of the tip. Just have to find the right size diameter opening for replacements. I'd imagine the stock ones have the same setup or are a slip fit that slide on and off with some resistance.
      11-03-2022, 08:50 AM   #3
zvery777
zvery777's Avatar
Drives: 2021 M550
These are the ones I've been looking into actually but many of the ones for sale appear to be longer and might stick out too much. I wonder if getting then from the actual exhaust could fix this issue instead of going for the aftermarket M performance ones.
      11-03-2022, 08:53 AM   #4
zvery777
zvery777's Avatar
Drives: 2021 M550
https://www.ebay.com/itm/15487635100...mis&media=COPY
These are the ones. Has anyone put these on? If so, how do they look?
      11-13-2022, 06:32 AM   #5
lukavergille
lukavergille's Avatar
Georgia
206
Drives: BMW 535i F10
2013 BMW 535i  [9.50]
Just FYI, Bought the 4 tips with the same price from Alibaba. Ebay sellers just ship them from China anyways so i assume they are the same products but double priced.
You should look for tips with 60mm (2.36 inch) inlet and they should fit well, but note that some BMW models have little pins on exhaust pipe which prevents OEM tips from sliding too far but doesn't let aftermarket tips to fit well and they stick out, so in that case you might need to just cut those pins off. I know 3 series have those pins but don't know if 5 series have them too, haven't checked on my car yet.
Planning to put them on soon and will let you know how it goes.
      11-13-2022, 08:19 AM   #6
zvery777
zvery777's Avatar
Drives: 2021 M550
Appreciate it, let me know how it goes.
      11-13-2022, 08:53 AM   #7
Trian
Drives: 2015 535i M-Sport
Ditto
      11-25-2022, 10:16 PM   #8
zvery777
zvery777's Avatar
Drives: 2021 M550
Originally Posted by Trian View Post
Ditto
Any updates?
      11-29-2022, 09:23 AM   #9
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
The F10 does not have the nubs that the F30 has. F10 tips are welded on.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      11-30-2022, 03:32 PM   #10
zvery777
zvery777's Avatar
Drives: 2021 M550
This guy filmed a video for me showing they are removable, I'm confused now...
      11-30-2022, 06:51 PM   #11
StradaRedlands
StradaRedlands's Avatar
Drives: 2006 BMW 330i MT
2006 BMW 330i  [8.21]
2009 BMW 328i Touri ...  [7.90]
2013 BMW X5 35i  [7.63]
2011 BMW 528i  [8.75]
2006 Mazda3  [5.50]
My OE chrome tips slide off. I was going to put some E30 gray ones on, but they didn't fit. Slid the original ones back on.
      12-01-2022, 05:57 PM   #12
Unspec
Unspec's Avatar
1300
Woah, really?! When I tried to remove mine, they were NOT coming off. Maybe they got essentially corrosion welded on?
Edit: Woah, you're right! TIL
https://f10.5post.com/forums/showthread.php?t=602868
2015 BMW 535xi
      12-01-2022, 06:04 PM   #13
zvery777
zvery777's Avatar
Drives: 2021 M550
😆 Apparently WD-40 will do the trick! I feel like mine are probably corroded to the pipe as well.
      12-01-2022, 11:59 PM   #14
Unspec
Unspec's Avatar
1300
I believe the tips are aluminum but the pipe is steel, so galvanic corrosion maybe?
2015 BMW 535xi
      12-04-2022, 05:04 PM   #15
StradaRedlands
2006 Mazda3  [5.50]
Good deal! Mine came off (and went back on) without any drama. WD-40 of PBB sounds like a good move!
      12-04-2022, 05:37 PM   #16
M_Bimmer
M_Bimmer's Avatar
583
Drives: G12 B7, G07 XB7, F02 B7, 991.1
Although the thread has turned toward aftermarket exhaust tips, I can confirm that the M-Performance tips (P/N 18-30-2-354-364), referenced by SWFLf10, do NOT fit on a bare (factory tip removed) 535 tail pipe end.
BMW increase the exhaust pipe at the very end to fit "big" exhaust tips on them....so now I have two very nice bookshelf decorations until I can get the factory M-perforance muffler.
