11-01-2022, 09:11 PM | #1 |
![]() ![]() 36
Rep 171
Drives: 2016 BMW 535ix
535ix M sport exhaust tips
Hi everyone. I'm looking to replace the exhaust tips on my F10 and wanted to ask those who have done without having to do any modifications to the exhaust (want to keep it stock): is there a good seller/place that offers tips that fit without issues?
Dual or quad does not matter to me as long as they fit without issues. Thank you! |
11-03-2022, 09:07 AM | #2 | |
![]() ![]() ![]() 181
Rep 386
11-03-2022, 09:50 AM | #3 | |
![]() ![]() 36
Rep 171
11-03-2022, 09:53 AM | #4 |
![]() ![]() 36
Rep 171
https://www.ebay.com/itm/15487635100...mis&media=COPY
These are the ones. Has anyone put these on? If so, how do they look? |
11-13-2022, 07:32 AM | #5 |
![]() ![]() 115
Rep 152
Drives: BMW 535i F10
Just FYI, Bought the 4 tips with the same price from Alibaba. Ebay sellers just ship them from China anyways so i assume they are the same products but double priced.
You should look for tips with 60mm (2.36 inch) inlet and they should fit well, but note that some BMW models have little pins on exhaust pipe which prevents OEM tips from sliding too far but doesn't let aftermarket tips to fit well and they stick out, so in that case you might need to just cut those pins off. I know 3 series have those pins but don't know if 5 series have them too, haven't checked on my car yet. Planning to put them on soon and will let you know how it goes. |
zvery77736.00 StradaRedlands1162.50 |
11-13-2022, 09:19 AM | #6 | |
![]() ![]() 36
Rep 171
11-25-2022, 11:16 PM | #8 |
![]() ![]() 36
Rep 171
11-29-2022, 10:23 AM | #9 |
![]() ![]() 882
Rep 2,300
The F10 does not have the nubs that the F30 has. F10 tips are welded on.
2015 BMW 535xi
11-30-2022, 04:32 PM | #10 |
![]() ![]() 36
Rep 171
11-30-2022, 07:51 PM | #11 |
![]() ![]() 1163
Rep 1,036
Drives: 2006 BMW 330i MT
12-01-2022, 06:57 PM | #12 |
![]() ![]() 882
Rep 2,300
Woah, really?! When I tried to remove mine, they were NOT coming off. Maybe they got essentially corrosion welded on?
Edit: Woah, you're right! TIL https://f10.5post.com/forums/showthread.php?t=602868
2015 BMW 535xi
12-01-2022, 07:04 PM | #13 |
![]() ![]() 36
Rep 171
😆 Apparently WD-40 will do the trick! I feel like mine are probably corroded to the pipe as well.
12-02-2022, 12:59 AM | #14 |
![]() ![]() 882
Rep 2,300
I believe the tips are aluminum but the pipe is steel, so galvanic corrosion maybe?
2015 BMW 535xi
12-04-2022, 06:04 PM | #15 | |
![]() ![]() 1163
Rep 1,036
12-04-2022, 06:37 PM | #16 | |
![]() ![]() ![]() ![]() 255
Rep 425
BMW increase the exhaust pipe at the very end to fit "big" exhaust tips on them....so now I have two very nice bookshelf decorations until I can get the factory M-perforance muffler. Last edited by M_Bimmer; 12-05-2022 at 10:10 PM.. |
