Retrofitting 4 Zone Climate Control on My 2016 BMW 550i xdrive
Thread Tools |
| 08-07-2024, 12:31 AM | #67 | |
![]() 952
Rep 1,231
Here is your favorite type....$70, and it comes with the rear connector.. https://www.ebay.com/itm/28525861584...Bk9SR8zn-bSlZA |
| 08-09-2024, 06:33 PM | #68 | |
![]() 1493
Rep 2,684
That said, I'm like 99% sure the actual brains of the control units are the same for non-heated, heated, and heated+cooled seats. It's just the button set that is different. You could, in theory, buy a basic control unit and then just buy BMW's button repair set that is applicable for your car. Haven't been able to verify this theory, however.
2015 BMW 535xi
| 08-11-2024, 02:57 AM | #69 |
Rep 223
This is for screen and temperature sensors wiring, the other one is sensors inside air vents and light for knobs and 12V socket has its own wires. I don't know exact wiring, i was replacing my air vents and temp knobs recently as some kid probably kicked it with foot so i wa not bothered which wire goes where, just plug out and plug in. I bought a car with rear climate.
| 08-17-2024, 11:11 PM | #70 | |
![]() 66
Rep 253
Why cant you buy the parts new from the bmw dealership? |
| 08-30-2024, 10:49 PM | #71 | |
![]() 66
Rep 253
For these 4 parts, can you buy them new at the bmw dealership and install them? - 64119290824 4-zone Distribution housing, upper (qty 1) - 64119241198 4-zone Distribution housing, lower (qty 1) - 64119166109 4-zone Distribution housing, temp sensor (+2 more required) - 64118319037 4-zone Distribution housing, actuators (+5 more required) Also, i cant seem to find Part # 64118319037 online, is that the right part number? I was thinking about doing this but with new parts, do you know if the parts above come with the wiring harnesses needed? |
| 08-30-2024, 11:17 PM | #72 | |
![]() 952
Rep 1,231
Typically most get the whole air distribution box from eBay with the wiring harness and all actuators (P/N 64118319037) in one assembly for a few hundred dollars. But to answer your question, all BMW Part Numbers listed for this retrofit can be purchased directly from your BMW dealership. |
| 08-05-2025, 09:04 PM | #73 |
![]() 1493
Rep 2,684
Okay, fresh new information for the retrofit.
tl;dr: F10 4 zone uses 11 motors, NOT 13. TIS is correct, realoem (on the motor part number page) is wrong. The part number for the lower housing is correct, so use the applicable part number realoem shows but check TIS for motor count. Wiring diagrams -> Body -> Heating and air conditioning functions -> choose one with FKA -> count number of motors, subtract two (recirculation motor and fresh air flap motor are irrelevant), and that's your number. Long version/background: For a long time, I could not get my retrofit to work properly. I bought the 7 series/RR version (64119241196), the one with two center air vent motors, totaling 13 on the housing (not including the recirc and fresh air motors). I thought it would work, and scratched it up to just BMW changing around PN's needlessly. Every time the calibration run was run via ISTA, it showed that the front center motors left and right as not installed, and I would get stratification motor blocking errors on certain motors. The air would come out of the wrong vents, and the blower motor was really loud since the flaps were behaving incorrectly and the air was hitting a "wall" when it didn't expect one due to a closed flap. I thought it was a dead motor or bad motor, since a bad/dead motor can cause auto addressing to fail, which is what tells the IHKA which motors control what. Turns out, it's because of the two center vent motors - the F10 IHKA expects 11 motors, and so the two extra motors were being addressed and "shorting" the addressing, resulting in the final two motors never being addressed. I was offsetting the addressing by two, basically. I found out this was the case when I dug into TIS's wiring diagrams more - I thought the recirc and fresh air flap motors "counted", and thus made up 13 motors, but then I checked the 7 series version of the same diagram. 15 motors. That's when it dawned on me that the recirc and fresh air flaps don't count when it comes to the number of motors, and the F10 actually only has 11 despite 13 being present on the wiring diagram. Looked more closely at the F10 wiring diagram, and conspicuously missing were motors for the center air vents. Checked the non-4 zone version of the F10 - 10 motors, including the recirc and fresh air. So technically 8. Which lines up with what realoem calls for. Thus, this is a rare case with realoem is misleading - it was the correct PN, but the wrong count. The lower housing for the 7/RR is NOT the one we need, and the one we need is correctly identified by realoem. So in terms of motor counts - check TIS, and not realoem. My fix: However, this doesn't actually mean you can't use the 7/RR lower housing. If you find a really good deal on one, the fix is rather simple (with both housings out of the car, ofc). Unscrew the center grille flap motors, pull out the actuator "rod" thing (pull hard, it pops out), and transplant the arm rod "things" from your stock housing over. They're the same, and go from the upper housing's outer upward facing vents, to the center vents. Do this one at a time, last thing you want to do is confuse yourself as to which goes where. The slots they go into is keyed, so don't worry about the actual orientation, just make sure each goes onto the correct side. Next, you need to jump the LIN BUS. You need to do this because the motors are daisy chained through the LIN BUS, and disconnecting the center grille motors will disconnect the LIN BUS from any downstream motors. Just snip the center two wires on the 4 pin/wire connectors that go to the center motors, and solder/crimp/whatever them together. This works because the actual plastic housing is universal - I know for a fact it is because the "prongs" that hold the black actuator rod is present on the lower housing, and the holes for the actuator rods that control the center vents is present as well on the upper housing, despite both being unused on the 13 motor variant. The LIN BUS jumping works because it simply no longer sees a motor, and just continues to the next one, thus converting it to an 11 motor housing. Me personally, I had to do this testing with my dash still in, so it was a bear of a time getting the motors out - actually had to drill a 3/8 hole into the metal dash support to get to one of the screws (shouldn't affect the strength, I hope...). This also meant that I couldn't jump the LIN BUS wires easily, due to how short the connectors are and having to work around the dash. So I just jumped them with some breadboard connectors for now - if they're good enough for ardunio's, they should be good enough for LIN BUS. I also could not get the actuator rods from my old housing in, there simply isn't enough space, so for now the center grille flaps are just perpetually open. Oh, another tip: run the ISTA program that puts the flaps in the installation position. It makes removing the upper from lower during uninstall a lot easier. Note each flap's position on the old housing, take off the motors from the new housing, and mimic the flap positions from the old onto the new. I had a bear of a time getting the upper onto the lower because the flap kept catching since I didn't do this.
2015 BMW 535xi
| 11-22-2025, 04:59 PM | #74 | |
Rep 5
I have a pre-LCI F11 with the standard climate controls, I plan on fitting the upgraded controls in the front only. I've read on other posts that coding is required as a pre-LCI, am I correct in saying that the 4NB you've mentioned is what I need to code in to ensure it all works (including front heated seats)? Many thanks! |
| 11-22-2025, 07:45 PM | #75 | |
![]() 952
Rep 1,231
If you have a pre-LCI front climate control panel (it'll have a large external "drum" sensor mounted on the rear, you should also try to use a pre-LCI rear climate control panel which it will have the same old-style sensor too. Let us know if you manage to get an LCI coded properly in your pre-LCI. I'm about to reinstall a full 4-zone system in a '16 F10 550. Should go pretty smoothly.....since I just removed it from a recently owned '14 F10 535. The air stratification box is still a pain to install. Good Luck! |
| 11-27-2025, 07:44 AM | #76 | |
Rep 5
Installed it yesterday (along with an MMI box for Android Auto), and coded in 4NB, it does in fact seem to work! Whilst I have the centre apart I could see the two vents in the centre, they both open or close at the same time, and are controlled by the driver-side controls, but the passenger side vents do get different temperatures to the driver side (excluding the centre passenger vent). How much more work would it be to fit the rear dual-zone controls? I'm assuming I need wiring for those, as well as a rear blower motor? Not sure I'm too fussed about the hassle as I don't sit in the back lol, but if it's easy I might consider it - I'm going to pull the center console apart to attempt an iDrive Touch controller fitting soon (although I'm realising I might not succeed as they have different CAN systems :/ ) |
| Bookmarks |
| Tags |
| climate control, f10 |
| Thread Tools | |
