07-12-2013, 06:35 PM | #1 |
BxBadBoyy88
61
Rep 360
Correct Tire Pressure??
Can someone tell me what I should have on my 20" wheels at the front and rear??. I'm currently at 36 at the fronts and 39 in rear.
Thanks guys
2013 AW 535Xi
07-13-2013, 09:20 AM | #3 |
Rep 937
Factory recommended pressures for a 535 xDrive (with 20" tires) are 36psi and 44psi (front/rear) for tires specified with 95Y XL / 97Y XL load ratings (front/rear). Generally it is recommended that you start with the factory settings and adjust from there. If your tires load ratings are higher than the factory tires, you can generally adjust your pressures down a bit, if your tires load ratings are lower than the factory tires, you should generally adjust your pressures up a bit.
Experiment a bit and see if you can find a pressure that feels good to you. Many people experience a huge ride quality difference by changing pressures a few psi. I would say keep within 5psi of the factory recommendations, and remember to never exceed the maximum pressure listed on the sidewall of your tire. |
07-14-2013, 10:29 PM | #4 | |
BxBadBoyy88
61
Rep 360
Thanks guys!!
2013 AW 535Xi
07-17-2013, 08:12 AM | #5 |
mrainv23
30
Rep 224
I am running my 20 inch vossen wheels at 40psi.
2014 BMW M6 Gran Coupe F06/M Performance Black Grille/20% Tint/ Exec Package/ Driver Assist Plus/ Black on Black
Sold-BMW 550i F10/Dinan S3/ Eisenmann Race Exhaust/ Vossen CV3s |
