2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Tuned N63tu Super Knocking Codes
      10-04-2020, 10:20 PM   #1
mattavino
Drives: F10 550, E38 750, E36 M3, etc
Hello everyone,
My first post here will be a negative one, hah.
My '15 550i, with DudMd tune, downpipes, NGK plugs gapped to 0.022; started giving me some hesitation at higher rpms when going WOT, it got worse (with no CEL or DT malfunction), so I pulled the codes and came back with super-knocking on cylinders 1, 2, 3, 4, 5!
Ignition coils are new, plugs are new, mafs are new, fuel rail pressure seems to reaching 2900psi without issue.
Idle surges SLIGHTLY, barely noticeable, which seemed to be fixed with mafs, then came back.
My theory is that injectors are leaking down a bit. I don't believe it's an octane issue, seeing as it got worse over time. I'm running 93.
I need to check AFRs again to see if my theory holds true.
Codes;
102A22 Air mass flow sensor, operating range: Air volume too high
152D08 Super-knocking: Injection switch-off
14401C Super-knocking, cylinder 3: Fuel injection deactivation
14401A Super-knocking, cylinder 4: Fuel injection deactivation
152208 Super-knocking, cylinder 2: Fuel injection deactivation
152108 Super-knocking, cylinder 1: Fuel injection deactivation
144021 Super-knocking, cylinder 3: Continuous injection deactivation
152508 Super-knocking, cylinder 5: Injection switch-off
201201 DME, slave, protection against tampering: data manipulation detected (obviously lol)
Any insight?
      10-06-2020, 11:18 PM   #2
550l
Drives: 2016 F10 550i x-drive
How many miles are on it?
      10-11-2020, 01:21 AM   #3
mattavino
89,000
      10-28-2020, 11:52 AM   #4
mattavino
Injectors, as suspected, fixed the issue.
Tags
codes, knock, n63, n63tu, superknock, tune, tuned
