2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Anyone have a lift?
      07-10-2020, 05:52 PM   #1
BimmerHausPerformance
513
Drives: 2011 535i 6MT
2011 BMW 535i  [0.00]
Anyone have a lift?
I am about to purchase a lift for my home garage so I can park my 535 under my project car. Anyone have any thoughts? I'm obviously not wanting to spend a ton... this is what I'm looking at:
https://www.gregsmithequipment.com/A...ty-2-Post-Lift
2011 F10 S55 6MT
      07-10-2020, 07:03 PM   #2
Trainwreck914
Trainwreck914's Avatar
Drives: BMW F10 F15 E39 E90 E53
Go for it. Not bad as far as pricing. I use a quick jack only because I don't have the ceiling height in the garage.
      07-10-2020, 11:17 PM   #3
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
I wouldn't park your project car on a 2 post, it's not very safe and you will wear the suspension by drooping it all the time. If you're trying to find a parking solution, a 4 post is a lot better. In fact, some manufactures will void the warranty if you using 2 posts as parking lifts.
The lift you linked is pretty good from what I hear. JerryRigEverything installed the 5 ton version (https://www.gregsmithequipment.com/Atlas-BP10000) and he seems to like it. His install video:
2015 BMW 535xi
ISTA VM Setup/Tutorial
      07-11-2020, 01:03 PM   #4
513
Thanks for that video. I wonder why they didn't just re-enforce or re-pour the concrete WHERE the posts were going vs. doing the whole slab. It's scary to think that until I actually drill the holes I won't know for sure if my slab is inconsistent or not.
As far as the suspension getting stretched and using it as storage... well, I'm not sure I'll have suspension for quite awhile on this car - it's a project. And once it's done, I won't need to store it in the air per se. Plus it's an e30 and will be extremely light so I wouldn't worry about the lift itself especially when it'd be resting on the safety locks.
That video made me excited about the lift, it looks very nice!
2011 F10 S55 6MT
      07-11-2020, 10:07 PM   #5
ziekxq
Drives: 2011 535i xDrive
The question should be... Do you even lift bro? Lol
      07-11-2020, 10:23 PM   #6
513
Not sure I understand.
      07-11-2020, 11:10 PM   #7
Themarkymark
Drives: 2014 Imperial Blue 535i xDrive
I would say check for automotive equipment vendors in your area, chances are they have used models of brand new lifts (Rotary, Challenger etc). This is import because, like anything else, lifts require maintenance and finding parts for the lesser know, and likely “imported” brands, can be very difficult.
I just found a 2010 10,000lb Rotary Lift for $1850 installed! Deals to be had for sure on quality used units.
2014 535i xDrive | MHD Stage 2+ | ER Catless DP | ER Charge Pipe | G-Plus Intercooler | Walbro 450 LPFP | Staggered 20” Avant Garde M359 |
      07-11-2020, 11:17 PM   #8
513
Good advice!! What kind of vendors are we talking? Can you give me an example?
      07-12-2020, 12:39 AM   #9
Themarkymark
Search for “automotive equipment sales“ on Google. Most local companies that sell and service lifts also have used units available. Even if they aren’t very close by, they might be willing to drive out, possibly with a surcharge.
I actually found mine through Craigslist, however they are also one of the dealers/servicers. Check Facebook marketplace too. I’ve been all over the place bargain hunting to try to outfit my full-service shop.
      07-12-2020, 12:14 PM   #10
ziekxq
Epic fail on my end.
      07-12-2020, 03:26 PM   #11
Unspec
Unspec's Avatar
1300
It's just a meme:
https://knowyourmeme.com/memes/do-you-even-lift
I think he did the whole slab just for peace of mind. I personally would do the whole slab, I don't trust the idea of only reinforcing the area under the posts, especially in my own garage.
2015 BMW 535xi
      07-12-2020, 06:11 PM   #12
513
Originally Posted by Unspec View Post
It's just a meme:
I figured it was something that was over my head... I'm getting old.
2011 F10 S55 6MT
      07-13-2020, 10:17 AM   #13
513
I just talked with GSE and they said this CAN be used for storage as long as the arms are resting on the safety locks and not resting on the hydraulics to hold it up, you are fine.
Also, they said if I hammer drill and the slab is less than 4" I only need a 4x4 section at 3k psi - I don't even need to do rebar re-enforcement. So that is doable vs. doing the WHOLE slab.
2011 F10 S55 6MT
      07-13-2020, 10:20 AM   #14
Unspec
Unspec's Avatar
1300
Also, they said if I hammer drill and the slap is less than 4" I only need a 4x4 section at 3k psi - I don't even need to do rebar re-enforcement. So that is doable vs. doing the WHOLE slab.
I'd still do the rebar tbh
2015 BMW 535xi
      07-15-2020, 08:58 PM   #15
513
If I go that far I'll spend the extra 10 bucks on rebar
2011 F10 S55 6MT
      07-22-2020, 01:31 PM   #16
513
So it begins. I just made room in my electrical panel for the 2 pole 220 run that I'll need for the lift. I'll put an outlet at the lift motor so I can use that same 220 for a welder.
Made an adjustment to the garage door so I can get clearance for the lifted car. Needs some tweaking but I was more proving to myself I could get the door up high enough.
GSE said the lift will be ready for pick up here soon and this is going to make working on the car SOOO much easier.
2011 F10 S55 6MT
      07-23-2020, 01:32 AM   #17
Themarkymark
Nice! Drill a pilot hole yet? Are they doing the install or are you handling that? It’s pretty straightforward but my guys showed up with laser level setups, chalk-lined all over the place, definitely better/quicker job than I would have done.
      07-23-2020, 09:43 AM   #18
513
I have not done that yet. I'm going to to wait and see what happens the day I go to install. If I drill and I don't have 4" then I'll just stop and pour my 4x4 footers... lol. It'll be what it'll be!!!
I'm going to do the install myself. Do you have pics of your lift installed?
2011 F10 S55 6MT
      07-23-2020, 11:05 AM   #19
dzz
Drives: 2015 BMW 535xi, MHD Stage 2+
2015 BMW  [0.00]
That is great, now we know where to come when we need a lift to work on our cars
      07-23-2020, 11:06 AM   #20
513
Hey man, come on over!
2011 F10 S55 6MT
      07-23-2020, 10:06 PM   #21
Trainwreck914
Jealous...I want a lift.
      07-24-2020, 09:24 AM   #22
dzz
2015 BMW  [0.00]
I probably would if you have lived closer Thanks for the offer!
