2010 2011 BMW 5 Series Forum F10 Normal amount of misfires on N63B44U0 that can be tolerated |
03-04-2021, 12:21 PM | #1 |
X Eins in der Luft
12
Rep 81
Howdy,
I've run noncontinuous monitoring tests through the Car Scanner via ELM 327, and it showed some 4 misfires on 5th cylinder in the idle run. I remember having problems with engine shutters on N52B30U0, and back then it had done 100+ misfires weighted moving average in 10 cycles. That was a faulty ignition coil. Dealer shop replaced some coil (didn't say on which cylinder), and I wonder if this replaced coil is causing misfires. But even if it does, are these 4 misfires in the idle warmup run OK? Can this easily be tolerated? I'm asking because I have a 11-year-old N46B20, and last time I checked it showed 0 misfires in the 10 cycle WMA run and 0 misfires in the current run on every single cylinder. Thank you. |
03-04-2021, 01:48 PM | #2 |
Rep 2,595
Swap coils to a different cylinder and see if it follows.
2015 BMW 535xi
550bye1391.00 |
Tags |
misfire, n63, noncontinuous |
