2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications 550i from hell
      03-05-2021, 08:20 PM   #1
Wht550jersey
Drives: 2011 550i
550i from hell
Just got done replacing all 4 vanos and intercooler to dinan, vented the coolant started the car ran great for 20 mins, opened the coolant reserve and car started stumbling and fell on its face . I also got a ton of faults
      03-05-2021, 09:46 PM   #2
Unspec
Unspec's Avatar
1301
Drives: 2015 BMW 535xi
Clear the codes and see what comes back. The problem with a lot of non-ISTA scanners is they don't show if it's a stored code or a current code.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      03-06-2021, 12:27 AM   #3
550bye
550bye's Avatar
Drives: 2011 550i
2011 BMW 550i  [5.67]
Ouch, '550 from hell', welcome to the club. You're not a real N63 owner until you have more faults then miles driven, haha. Just kidding, but not really. Like Unspec said, you have to get ISTA setup.
kretzu can hook you up in the DIY section if you don't have a copy. You can check the FB groups too, a lot of guys will get on TeamViewer and help you with setup and basic diagnosis, assuming you're not already using ISTA. Good luck
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R.
      03-06-2021, 05:55 AM   #4
Wht550jersey
Drives: 2011 550i
Thanks guys going to try and get ista . I have had way to many problems with this car . Lmao . Also none of the codes will clear . Also have no throttle when startup . I'm wondering if the throttle body went .
      03-06-2021, 09:42 AM   #5
spielnicht
Petrolhead
spielnicht's Avatar
440
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
Sorry to hear about your troubles. LMK if you need help with ISTA setup.
This engine's rep is the reason I won't even tune it or install any aftermarket performance parts - it's hard enough just to keep it happy and operational as stock.
2024 X3 M40i
2014 550i
2008 Z4 3.0si 6MT
2011 Z4 35si (sold)
      03-06-2021, 12:37 PM   #6
Wht550jersey
Drives: 2011 550i
Thanks trying to get my hands on a laptop . Just odd I can't clear any of these codes
      03-06-2021, 07:30 PM   #7
AnotherM
Cole
Drives: 2016 m5 CP
If you cant clear the codes, it could be because what has caused them is an actual problem. Lind of like if you have a shorted sensor and the code wont clear.
      03-12-2021, 08:38 PM   #8
Trainwreck914
Trainwreck914's Avatar
Drives: BMW F10 F15 E39 E90 E53
Also some scanners are unable to clear codes. I've noticed this in the past. But I'm usually able to clear them with ista. But serious once return instantaneously
      03-13-2021, 08:43 AM   #9
Wht550jersey
Drives: 2011 550i
Ya I got ista going and nothing will clear . Just trying to figure out if it's a wiring problem or the dme went out
      03-13-2021, 09:58 AM   #10
AnotherM
Cole
Drives: 2016 m5 CP
I fried my dme when I removed the engine harness on bank 1. Had one of the ground wires not fully tightened and it fried instantly.
When I started the car, it ran like crap and had a bunch of similar codes.
      03-08-2023, 02:41 PM   #11
billowusu
billowusu's Avatar
17
Drives: BMW 335xi
Did you solve it? Having the same issue for 2 months straight. Ready to part my car out because of it.
