2010 2011 BMW 5 Series Forum F10 Slight vibrations at Idle |
06-02-2020, 10:51 PM | #1 |
Rep 199
Hey everyone. My 2011 535i seems to have very random, but slight vibrations when the car idles. I knew the culprit for this was my low fuel pressure sensor and my idle tensioner pulley but after having them both replaced the slight vibrations went away for a couple days and then came back. Maybe I am overreacting and being superstitious
Any help would be appreciated. Would like to also mention that the needle that shows RPMs does not move when it does this. |
06-03-2020, 09:35 AM | #3 |
Rep 452
I read that it could be injectors. I have the same issue. But don't want to just throw parts at it. But could be a number of the things as stated. Mounts. Coils. Spark plugs. Have yet to see a verified fix.
06-03-2020, 10:19 AM | #4 |
Rep 199
06-03-2020, 11:54 PM | #6 | |
Rep 199
06-04-2020, 07:08 AM | #7 |
Rep 452
It could very well be the engine mounts. I've changed numerous parts on my car. As I just hit 128k. I like to do preventative maintenance on certain components. Things that can leave you stranded. As my commute is 50 miles each way. So things like cooling and fuel delivery. I'm definitely due for motor mounts. So I'll put that on my to do list. But it's not really priority to me. As the idle issue doesn't concern me as much. And the car runs well. I wish I had a definitive answer. Would I like to fix the issue. Yes. If I knew for sure what the problem was. No codes for me in ista as well.
06-04-2020, 12:07 PM | #8 |
Rep 199
I find myself in a similar situation as yours. Everything works fine but I don't really find it logical to start dumping money into the matter. If it gets worse I'll know what to look for, thanks.
