2010 2011 BMW 5 Series Forum F10 Shaking on startup, high fuel consumption? |
05-18-2020, 02:20 AM | #1 |
Rep 30
Hello everyone,
A new happy member here, yet already in need of advise 535Xi ~70k miles I noticed my car shaking on startup till RPMs go a little down. Not horribly but noticeable enough. Also, I get around 17mpg with 60% highway/40% town with smooth throttle. I changed spark plugs and air filter just recently. Didn't really help much. I was trying to look through error codes with BMWaicoder - nothing really related to the issue. Will try to install Rheingold and give it another try. Previous owner of the car mentioned he had some hesitation upon acceleration. Dealership was supposed to replace vanos. But they ended up just cleaning it since the previous owner didn't have time to wait for a new part. Do you guys have any recommendations/ideas? I have a little bit of extended drivetrain warranty left, really want to fix the issue. I wonder if I can insist on replacing of vanos since they never did that at first time? |
05-18-2020, 05:46 AM | #2 | |
Rep 8
"This part needs to be replaced, but I'll just clean it and save a ton of $$$ for a temp fix, then pawn it off on the next guy!" |
ashmailusa4.50 |
05-18-2020, 07:47 PM | #3 |
Rep 79
You mean vanos solenoids and sensors. Yeah they can be cleaned or replaced. Do you have any codes from ista scan?
A note is to use good oil and proper change interval. |
ashmailusa4.50 |
05-19-2020, 01:22 AM | #4 | |
Rep 30
Generic scanning software didn't show any error codes so far |
05-26-2020, 10:09 AM | #6 |
Rep 441
What about coils? 70k might be about time anyways if original coils are still on. As a new owner, new coils will give you the sanity of knowing where your new mileage "baseline" starts on the coils.
Please verify this, but I recall seeing rough idle can point to coils - even though it sounds like it's only your cold start not your normal idle. 17mpg isn't abysmal, but agree you can hope for better.
2013 535xi M Sport (PWG) // PS2 // Spool fx150 // MHD // xHP // FTP Inlet // FBO: AR HF DP, Wagner IC, BMS Intake, VRSF CP
05-26-2020, 11:53 AM | #7 |
Rep 517
If you have an x drive there is a known issue with hesitation on launch. It's on this board somewhere.
Rough idle could be many things. Dirty MAF, unmetered air entering the system after MAF, spark plugs and coils, 02 sensors, vacuum leak, vanos cleaning like you mentioned. Try resetting adaptions. 17 mpg also sounds like you have a tune on your car. Have it flashed to stock.
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
05-26-2020, 02:12 PM | #8 |
Rep 441
+1 on the xdrive hesitation on launch. When I startup, I need to wait until after the cold start and my revs die down before I drive off, or else I sputter and even stalled once.
On resetting adaptations, just a word of caution there - I don't have any more knowledge than seeing it mentioned occasionally and this article - but wanted to share: https://www.xhpflashtool.com/blog/adaptions/ "So, with that knowledge, what is it good for to reset adaptions regularly? Simple answer: For nothing. In rare cases, on transmissions with already very high positive adaptions, this can even lead to a situation, where your transmission will refuse to shift and you basically have to rebuild it, before it will work again. And that is the reason, why adaptions do not get reset by the dealer on service work. There is no reasons for it, unless hardware on the transmission has been changed."
05-26-2020, 11:03 PM | #9 | ||
Rep 30
I would expect misfire being more evident and constant in this case. Am I wrong? Quote:
Also, adaption reset - meaning adaption of the transmission? |
05-26-2020, 11:45 PM | #10 | |||
Rep 441
05-27-2020, 01:04 PM | #11 | |||
Rep 517
There's a ton on different bimmer models search for "BMW xdrive hesitation"
