05-27-2023, 01:24 PM | #1 |
Rep 16
Door seal?
Hello everyone, I was wondering if any of you can help me out on this one. My F10's passenger door has a hard time opening from the inside and I'm assuming it's the ripped the seal around the door that's making it harder to open from inside. To be more specific I can open the door from the inside handle but instead of opening easily I have to use a slight amount of force to have it opened completely. Is it from the door seal or something mechanical, and is there a DIY way to repair it or just simply replace the entire thing, and what is the part to replace the seal? the one I found from RealOEM is "51767182269" but I want to make sure.
Thank you all, I will post an image if you guys like. |
05-28-2023, 10:03 AM | #2 |
Rep 829
How hard is the door to open using the outside handle?
If it's much easier to open the door from the outside vs from inside handle, e.g. door does not stick, then I'd suspect that your interior handle, the cable from the handle to the door latch, or the door latch mechanism are faulty. If you still suspect that the door seal is the problem, have you tries to clean the seal and the door jamb area? There are two seals, one on the door itself and one on the door frame.. Not sure this helps...maybe some more info? |
Devosent1.50 |
05-29-2023, 08:04 AM | #3 | |
Rep 16
