04-22-2019, 05:52 PM | #1 |
![]() 17
Rep 59
Oil Measurement Inactive -- F10 550i
Hello. I just had my valve cover gaskets replaced, and when I got the car back, I could not check the oil level. I called the shop that did the gaskets -- it's in Atlanta, I am in Nashville -- and they said it is just the oil level sensor that is damaged. The shop here in Nashville says my ECU has been damaged from using the wrong ground bolt on the engine block. That seems illogical, but I have no clue. This is not an issue where I am simply not letting the car warm up to check the oil level; I am waiting for the car to reach normal operating temperature. Also, the oil temperature gauge is working. Has anyone ever run into this?
04-22-2019, 08:43 PM | #2 |
![]() 18
Rep 59
Hopefully it’s not your ECU, however I had the exact same issue. I had a faulty ECU which causes the oil level sensor to not show on my 535i. Dealership can do a quick scan to confirm if ecu is faulty or not
04-22-2019, 08:44 PM | #3 |
![]() 17
Rep 59
So you have heard of the ECU going bad and affecting this function?
04-22-2019, 10:26 PM | #5 |
![]() 17
Rep 59
04-23-2019, 08:04 AM | #7 |
![]() 17
Rep 59
04-23-2019, 05:41 PM | #8 |
![]() 43
Rep 175
Hehehe......
This sounds like a good case of a BSD fault. I accidentally left a ground bolt loose after I did my large valve seal project on my 550i. It leads to three main components of the BSD system. Oil level sensor Alternator DME I changed out the alternator, no change Changed out the oil level sensor, works beautifully. Go the cheapest route first, and change out the sensor. I replaced the alternator as a precaution. I'm happily will spend 250 dollars on a low mileage x5M alternator and a 7 dollar oil level sensor from the junkyard 2007 750li vs a 3k plus dme......and that isnt the issue lol. Change out the sensor, make sure the ground bolts that holds the injection harness are secured/torqued report back. |
04-23-2019, 05:48 PM | #9 | ||
![]() 17
Rep 59
04-23-2019, 06:30 PM | #10 |
![]() 43
Rep 175
I've done alot of research after founding the issue of the oil level inactive. Newtisinfo carry alot of info in terms of the system functionality.
Essentially, it is a special cable that transfer delicate data between the oil sensor, the alternator and the dme. The dme controls the voltage output and sends/receive info to the alternator. The efficient dynamics( charging while coasting) uses the bad system. If it fails( and I know this as I test this) the alternator goes to basic charging of 13.5 to 13.7 volts. It is okay to drive but your battery will die out earlier due to irregular charging. If it is working, your charging spikes up to 15.2 or so volts as you coast and then 13.5 or so as you drive.....and obviously your oil level will function. So......your sensor has a bsd sensor, the alternator has a bsd "generator " if you will. And the dme gets all the info. |
04-23-2019, 07:17 PM | #13 | ||
![]() 17
Rep 59
04-23-2019, 08:06 PM | #14 | |||
![]() 17
Rep 59
https://static.nhtsa.gov/odi/tsbs/20...49679-2750.pdf I hope and pray my DME is not fried. |
04-23-2019, 11:38 PM | #15 |
![]() 43
Rep 175
Sorry, I was at a seminar and was taken to and from there. Also my phone was at 1% while answering the above post lol.
I see you found the newtisinfo page. That is specifically the harness I was taking about. You know the sad part? It was only ONE bolt that was slightly loose that caused the demise of my oil sensor and alternator. The dme should be okay since the oil sensor and the alternator takes the blunt force first. They are more sensitive and if the connection is broken, it won't hurt the dme or others. It is a Russian roulette, 1 of the 3 chance that will end badly on a costly dme. I hope and pray also that is just your sensor or alternator. But triple check those bolts. Allen head, I believe it is a 5 or 6mm. Use a ratchet. |
04-26-2019, 06:34 PM | #16 | |
![]() 17
Rep 59
04-26-2019, 09:15 PM | #17 |
![]() 43
Rep 175
Wow....disconnected alternator wire. That isn't right.
Alternator can still be faulty regardless if it charges fine since it has a bsd function integrated to the alternator. You'll know only of its function when you are coasting( your mpg gauge goes to the blue battery side). I hope it is the sensor. I have one extra laying around in case but never used it. No reset required. I literally plugged the replacement while the faulty one is still in the pan to diagnose the issue and my oil level became active, of course it was saying it was reading, please wait. |
04-26-2019, 09:18 PM | #18 | |
![]() 17
Rep 59
04-26-2019, 09:20 PM | #19 |
![]() 43
Rep 175
It will do that regardless, but you wont know until you are physically measuring the output. The hidden message will show you the parameters while you drive.
04-26-2019, 09:21 PM | #20 |
![]() 43
Rep 175
EL Jeffe 5593.50 |
04-26-2019, 09:22 PM | #21 |
![]() 17
Rep 59
I am way out of my league here. How do you measure alternator output while driving? I just used a volt meter, hooked red to red, black to black, and it read 14.3.
04-26-2019, 09:22 PM | #22 |
![]() 43
Rep 175
As you coast, the voltage will spike to 15.2volts or so. Then when you step on the gas to accelerate, the voltage will go back down to normal charge of 13 to 14volts.
I'm 100 percent sure it wont work if your oil is inactive. Watch the YouTube video to show you how to get to the menu. You wont need your multimeter after this. It is very useful for diagnostics. |
