2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Map update problem
      08-20-2018, 04:02 PM   #1
anthonywill3
Drives: 2015 M5 CP
Talking Map update problem
Loaded 2019-1 NA NEXT map for my 15 F10 on to 64GB USB (formated fat32), idrive recognizes update, then gets hung on "please connect the usb device 1". Only option is to cancel.
I have 4 folders (1,2,3,4) and 3 files .nfm, .pkg, and .pkg.sig on the root of the drive.
What am I doing wrong?
      08-20-2018, 07:11 PM   #2
NinetyEight740
NinetyEight740's Avatar
Drives: 2 - 2013 535i msport
2010 E91  [0.00]
Where did the maps come from?
      08-20-2018, 10:16 PM   #3
jayster0966
jayster0966's Avatar
Drives: 2011 535i
Just updated my maps as well from https://bmwnavupdate.com/ 2018-2 and all went smooth. Just did not expect to take almost 40 minutes of idling in the driveway while it updated from the glove box USB.
      08-21-2018, 07:23 AM   #4
anthonywill3
Drives: 2015 M5 CP
got it from a Facebook group... I also had the same problem with a 2018 map that I downloaded from **************.com
      08-21-2018, 08:39 AM   #5
AP
AP's Avatar
2777
Drives: G30 M550
Well that is perhaps your answer......
      08-21-2018, 08:49 AM   #6
anthonywill3
Drives: 2015 M5 CP
had the same problem with a 2018 map that i downloaded from OEM navigations.
Is there a better source for the map files?
      08-21-2018, 08:56 AM   #7
NinetyEight740
2010 E91  [0.00]
The dealer. Paying for the update would be a good start.
      08-21-2018, 11:19 AM   #8
AP
AP's Avatar
2777
Drives: G30 M550
Assume you have a fsc key as well.
They can be download from other sources, don't recall where I got mine now when I had a f10. I do recall using esys to create a fsc code though
      08-22-2018, 07:18 AM   #9
wcr3d
Drives: 2013 535i XDrive M Sport
If I'm not mistaken it should be one file in .bin format.
      08-28-2018, 05:35 AM   #10
andykap
Drives: '15 BMW 535 MSport
Reformat the USB drive. Or try another. I had a similar issue and changed the drive and successfully did the update.
      08-29-2018, 12:12 AM   #11
mness
Drives: 2013 535iM
That's the BMW phone connectivity update, not the map update.
      08-29-2018, 12:19 AM   #12
mness
Drives: 2013 535iM
^^ THIS ^^
If reformatting and recopying doesn't work, perhaps your source is the problem. Mine worked fine from here: https://cartechnology.co.uk/showthread.php?tid=37970
And there's this thread, but I haven't tried the one referenced. https://f10.5post.com/forums/showthread.php?t=1524402
2013 535i M-Sport: Carbon Black with Oyster/Black Dakota, SAT, Driver Assistance Pkg, Premium Pkg, Multi-Contour Heated Seats, Navigation, H/K stereo. Michelin Pilot Sport 4S non-runflats, M5 grille, Painted reflectors from IND.
