2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Forgestar F14 Super Deep Concave F10 Fitment Guide.
      02-09-2016, 04:24 PM   #133
jooobi3
jooobi3's Avatar
Drives: 2011 BMW 535i XDrive
Originally Posted by xenoz535 View Post
im on front deep concave 9.5 et 22
and rear super deep 11 et 44 super flush no rubbing
my only remorse should of went super deeps all around might just buy 2 wheels later this spring for that look T_T
Will the super deep rub at all in the front?
Mind posting any pictures?
      02-10-2016, 05:12 PM   #134
exia_m3
exia_m3's Avatar
181
Drives: 2017 F80 ZCP MW/SO
2013 BMW E92 M3  [0.00]
2017 F80 M3  [0.00]
http://f10.5post.com/forums/showthread.php?t=1190696
bad at sending pics here is a pic of them scroll through near the end
and I edited my last post front 20x9.5 deep at et 22
and rear 20x11 super deep et 40* and
NO RUBBING And I did not choose these offsets forgestar did all the calculations so if you want SDC all around they know what offsets and know what they are doing to trust your rep.
Current: 2017 F80 ZCP MW/SO @EnzoRacing PTF BM3 STG 2 GTHaus Meisterschaft GT2 Exhaust SSR Intakes
Swift Springs
@drivingwithbenny
      02-10-2016, 05:17 PM   #135
jooobi3
jooobi3's Avatar
Sounds good! Looks like this might be my next set!
      04-25-2016, 07:01 PM   #136
spssbmw
Drives: 550i
With F14 SDC 20x9.5 et11, on stock 550i M-Sport suspension, will I be able to step up on the front tire size to 245/40-20 ? instead of using 245/35-20.
      04-25-2016, 07:17 PM   #137
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
That will make the tire a bit taller...not sure exactly how much? But If you go to tire rack.com you can put the tire size on and see how much overall the tire diameter would be between both sizes
      04-28-2016, 09:21 AM   #138
Russkey
Russkey's Avatar
Drives: '12 BMW AW 550xi
2012 550xi  [10.00]
Hey guys, I'm a little lost. So what's the perfect offset for 550 x-drive dropped on ACS springs? I'm worried about the fitment with 550 calipers. I'm considering 20' F14 SDC btw.
'15 Porsche Macan S / Black & Garnet Red / 20" RS Spyder Wheels / CF trim / Red Calipers / Black Rear Badge.
'12 AW 550xi / Dinan S2 / Arkym CF Spoiler / 3D Design Style Splitter / Eisenmann Race Exhaust / 20' HRE FF01 / ACS Springs / CF Grill / CF 3D Design Diffuser / Blue Calipers...
      04-29-2016, 09:51 AM   #139
Russkey
Russkey's Avatar
2012 550xi  [10.00]
Anybody? ^^^
      04-29-2016, 01:17 PM   #140
Zer0Cool92
Drives: blue metallic
Originally Posted by Russkey
Anybody? ^^^
I have 20x9.5 Sdc +11 front. No issues w stock suspension. Another guy was slammed on hr sport springs with the same spec wheels up front and had no issues with caliper
      05-01-2016, 06:48 PM   #141
spssbmw
Drives: 550i
Anybody? ^^^
What size front tire were you running?
      05-15-2016, 02:41 AM   #142
Zer0Cool92
Anybody? ^^^
245/35/20
      06-07-2016, 03:05 PM   #143
rebuk
Drives: 2015 535i
Looking to pick up this wheel/tire combo. Did you all order from one place or local shops?
Trying to shop around and want to make sure I can find the best deal, if thats even possible.
If you have any referrals on who I should use, open for suggestions.
Cheers.
      06-08-2016, 05:00 AM   #144
lsturbointeg
Cheers.
i bought from our site sponsor GetYourWheels.com great guys there and they hooked me up with a pretty damn good deal also, from what i've seen they can do any Bespoke finish to those F14's. plenty of examples of their Bespoke finishes on the F14's if you browse the link
http://f10.5post.com/forums/showthread.php?t=1002940
these i love!
      12-25-2016, 01:22 PM   #145
Sp1ke
Sp1ke's Avatar
Drives: e82
What lug nuts are yall using? Will the stock lugs work?
      12-27-2016, 05:18 AM   #146
lsturbointeg
I did not use the stock lugs rather the BMS Titanium lugs from BurgerTuning! i'm sure the stock lugs would work but i went for purely aesthetics
      02-18-2017, 10:15 AM   #147
Luong
Luong's Avatar
25
Drives: M
Which tire size is better for the rear @ 10.5 on H&R springs - 275 or 285s?
      07-30-2017, 11:14 AM   #148
ey2001
ey2001's Avatar
310
Drives: F10 535i 6spd
Will this spec fit our cars?
Fronts: 20x9.5 ET+18
Rears: 20x11 ET+37
      08-01-2017, 08:00 PM   #149
Teddylongtooth
ZEROdoubleZERO
Teddylongtooth's Avatar
228
Drives: 2011 550i m sport
Rears: 20x11 ET+37
The rears will rub and poke out past the fenders unless you put some negative camber which will destroy your tires. The fronts will stick out past the fenders too, those will not fit correctly.
      08-01-2017, 08:01 PM   #150
ey2001
ey2001's Avatar
310
Rears: 20x11 ET+37
The rears will rub and poke out past the fenders unless you put sime negative camber which will destroy your tires. The fronts will stick out past the fenders too, those will not fit correctly.
Thank you for your reply...
      08-01-2017, 08:43 PM   #151
Teddylongtooth
ZEROdoubleZERO
228
No problem.
      08-01-2017, 09:11 PM   #152
ey2001
ey2001's Avatar
310
If Lacster is running 20x9.5 et 11... wouldn't the 20x9.5 et 18 go in more?
      08-01-2017, 10:01 PM   #153
Teddylongtooth
ZEROdoubleZERO
228
He modified his car to make those fit, he pulled his front fenders and ran alot of tire stretch to make that work. I have 20x9 +28 on my fronts and they are flush, those wheels your looking at will stick out 17mm more than mine. But it depends on the look your going for? His car was slammed on kw coil overs and basically stanced, I bet a million dollars those rubbed. If you read this whole thread there alot of people who claimed they were going to do what he did but nobody did. I know the rears will rub, I have 20x11 +38's and they rub with no negative camber, so what you really needed ask was will these fit with or without a lot of modification. Those offsets will not fit without modification and trying different tires sizes and they will rub.
      08-01-2017, 11:10 PM   #154
lsturbointeg
Rears: 20x11 ET+37
here's my rears at 21x11 38mm
