01-14-2021, 06:01 PM | #1 |
Rep 81
Wheel advice
What's good everyone, I need a bit of help on some wheel sizing. I'm looking to get I believe the 343m wheels with the following size: 20x9 et34 front 265/35R20. 20x10 et 34 rear 295/30R20
I wanted to know if anyone would be able to impart some advice on whether these would rub or not. They seem a bit large for the front but I'm not an expert so I've come to y'all. Would spacers help? Any help is appreciated thanks! |
01-14-2021, 11:55 PM | #2 |
Rep 2,591
I run 255/35/20 295/30/20 on my 343's with the same offsets. xDrive, so I downsized the fronts a tad. From my experience, 285's fit better on the rears, because 295's poke a tad due to the non-m5 fenders being not as wide. As for rub, you should be fine with what you posted.
2015 BMW 535xi
gr8brwnshark26.50 |
01-15-2021, 01:43 AM | #3 | |
Rep 81
01-15-2021, 06:45 PM | #4 | |
Rep 2,591
2015 BMW 535xi
01-16-2021, 06:22 PM | #5 | ||
Rep 81
01-17-2021, 09:46 AM | #6 |
Rep 110
I have a 530d (rear wheel drive) and put on some 343M wheels a few years back. The M5 and the M6 both have this wheel, but the M6 has a different offset and it doesn't fit on the F10 very well. The wheel specs you listed initially are correct for M5 wheels that fit on an F10.
I run 255s in the front and 285s in the rear and have had zero rubbing issues. I'm on my second set of Pilot Sport 4S's, so I've certainly put some miles on this set up. When I did all my initial research, some people had rubbing problems with 265s in the front and 295s in the rear, so I decided on the slightly narrower width. I've added some pictures that show the width of the setup in relation to the fender (I have not used spacers- just bolted these straight on), as well as some general pics. |
01-20-2021, 05:11 PM | #7 | |
Rep 81
02-22-2021, 11:37 AM | #8 | ||
Rep 10
02-22-2021, 12:00 PM | #9 |
Rep 2,591
Won't work. 285/30/20 with 255/35/20 results in a 1.1% difference in diameter, great than the 1% tolerance allowed. 245's on the same profile would be 0.4%
2015 BMW 535xi
