03-03-2020, 01:42 PM | #23 | |
Rep 1,299
I want to get Draggy but I I already spend too much money this time around on exterior stuff lol. Plus I want to get bigger rims... Ah I thought I would be done spending money on moding by now lol. |
03-03-2020, 01:46 PM | #24 |
Rep 1,445
Drives: F10 S55, E93 M3, E89 N54
You can hit 100 and you don't even feel it on the freeway... yea modding and spending, there is no end. Just have fun while you are doing it and enjoy it while it's not broken.
03-03-2020, 02:03 PM | #25 |
Rep 1,299
As long as engine and turbo running good than everything else can be fixed for cheap. I see trans used for dirt cheap for this car. Engine would be the only scary part.
03-03-2020, 09:44 PM | #26 |
Rep 1,299
New update... Oscillation is gone. We only did quick 3-4.5k rpm run to see how car is doing the he is going to make adjustments.
1st run: https://datazap.me/u/ziekxq/v20-1st-...=0&data=4-5-22 2nd run: https://datazap.me/u/ziekxq/v2-0-2nd...=0&data=4-5-22 |
03-03-2020, 09:50 PM | #27 |
Rep 1,445
Looks a lot better! How does it feel? Can't wait to see what he pulls out of the turbo.
03-03-2020, 10:27 PM | #28 |
Dream crusher
984
Rep 2,421
Wow nice lines! I'm sending him my logs tonight when the freeway clears.
IG: @bmwdoubles |
03-03-2020, 10:50 PM | #29 |
Rep 1,299
Car feels more powerful than when it was on 18psi TT tune for some reason. Smooth and scary lol, but I haven't push it too hard yet until the tuner looks at the logs. I just hope I can get at least 18 psi with 93 octane. I don't think you can do more than that unless going Helix.
03-03-2020, 10:51 PM | #30 |
Rep 1,299
Did you buy his tune? He is a cool guy... He was looking at my logs from TT and responding to me and helping me out even when I didn't buy his tune. I don't know any other tuner that would do that.
Bmw doubles983.50 |
03-05-2020, 04:53 AM | #31 | |
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
03-05-2020, 06:26 AM | #32 | |
Rep 1,445
03-05-2020, 11:49 AM | #33 | |
Rep 1,299
03-05-2020, 01:45 PM | #34 | ||
Dream crusher
984
Rep 2,421
Just FYI I don't have the micron filter and Spool has informed me that I'm good up to 550whp with the stock filter. So that's my goal with the DS tune. Also my car is good with the stock filter on e50 on cold start ups. It's rough with e60 so full e85 might require me taking out the filter or other, lpfp upgrade, micron filter, etc. I'll see what David can do about it. I also have to scale my MAF so that may resolve the issue too.
IG: @bmwdoubles |
03-05-2020, 02:29 PM | #35 |
Rep 1,299
I already did the lpfp stage 2 diy on my car so I'm good on that. I was just thinking of going the filter/HOD/e85 line from spool with Bluetooth analyzer. All depends on the pocket lol... But spool is coming out with the intake as well similar to your and showtimes design that I want to get. I going to probably order the breather cap next month just for piece for mind.
Bmw doubles983.50 |
03-05-2020, 07:57 PM | #36 |
Rep 1,299
03-05-2020, 08:31 PM | #37 |
Rep 1,445
Nice, a little overboost there but it does not drop off like doubles said his did, I am sure that is due to the tune! You going to Target higher boost at all? Has he messed with your timing?
03-05-2020, 08:42 PM | #38 | |
Rep 1,299
https://datazap.me/u/ziekxq/v21-2nd-...=0&data=4-5-22 |
03-05-2020, 08:51 PM | #39 |
Rep 1,445
Ok... That looks like you are peaking out now.. so are you close? How does it feel? AFR at 12.3 but Rock solid, I would imagine that's it until you get more fuel.
03-05-2020, 10:12 PM | #40 |
Rep 1,299
03-06-2020, 05:50 PM | #41 |
Dream crusher
984
Rep 2,421
So just word to the wise about oscillation and Wastegate adjustments.
Here's is a log I just did after following a YouTube video on WG adjustments for PS2. https://datazap.me/u/bmwdoubles/real...38;data=2-3-10 In this data log where I adjusted to 6.5inHg going between what the video recommended. You can definitely see WG oscillation. This maybe due not enough vacuum. Also potentially another leak. I'm checking for both and working with David to find out. If it's the vacuum problem just beware. I also have renewed the solenoid and vacuum lines and WG readjusted the other night. So the WG recommended setting highly suspect rn.
IG: @bmwdoubles |
03-06-2020, 05:59 PM | #42 |
Rep 1,299
What revision are you on? You're at least oscillate above boost target lol mine was below boost target. It took my car 3 revisions for clear oscillation. I have no more oscillation but car is over boosting during WOT shift. I send the logs to David for review. Only happens when manually shifting.... I wonder if the shifts are so quick that DME is having trouble catching up or something.
https://datazap.me/u/ziekxq/v21-rand...=0&data=4-5-22 |
03-06-2020, 07:35 PM | #43 | |
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
03-06-2020, 08:21 PM | #44 |
Rep 1,299
I'll check with him... I am already at 6.5in hg so I will go to 7in hg if he says we have to do that.
