2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Navigation installation...
      01-24-2012, 07:44 AM   #1
optima99
Visit Ireland, it's amazing!
Ireland
Drives: 435d Luxury & X3 2.0d SE
My brother has had his F10 530d for about a year. He ordered the car without navigation and would now like to install it.
I have replaced the radio in my F07 so I'm comfortable with my abilities to remove the radio & screen in his F10, however having removed his radio & screen is it simply a matter of installing the new (larger) screen (p/n 9 210 411) and CIC HDD head unit (p/n 9 223 402)?
1. Will the existing wiring suffice?
2. Is a specific GPS antenna required?
In other words is this simply a 'plug and play' exercise or is there a lot more to it?
I would be grateful of any advice or comments
Thank-you
      01-27-2012, 10:51 PM   #2
NGINWERK
Drives: 2011 BMW 528i
id like to do the same to mine
id like to do the same to mine id love some advice
      01-28-2012, 03:15 AM   #3
supeace
Drives: F10 520D
GPS antenna>>Farka connector type, you can reach it on ebay.
below web maybe more easy to get your parts.
http://www.bimmerretrofit.com/store/...te=common/home
      03-27-2012, 10:20 AM   #4
Tuesday
Frequent Flyer
Tuesday's Avatar
51
Drives: 535LCI
He will need FSC code to activate navigation most likely. All the information for CIC retrofit is out there - but CIC is generally not plug-n-play.
      03-28-2012, 09:47 AM   #5
snj1013
Drives: 2011 528i
It does need coding. There are a couple of including bimmer-tech.net. Patrys is the guy you want to get with. Here is a thread on similar retrofits. http://f10.5post.com/forums/showthread.php?t=590409
