| 03-12-2025, 08:44 AM | #3631 |
![]() 135
Rep 119
Drives: '15 535i xDrive M-Sport, E30
| 03-13-2025, 03:08 PM | #3632 |
BMW enthusiast since 2004
792
Rep 414
Wired up passenger side+doors for soft close and rear lock installed. 3/4 doors now have working soft close. As soon as the new soft close motor arrives I can do the last door.
Also waiting pin's for the fuse box so I can install all wires nicely. |
StradaRedlands10085.00 |
| 03-15-2025, 11:25 AM | #3633 |
792
Rep 414
Looked at parts to retrofit LDW (S5ADA) and LCW (S5AGA). As it seems LDW is pretty simple to retrofit as I already have kafas. LCW is not too bad either, since parts are quite cheap. Wiring has to be diy as the kit's I found cost way too much (with all needed parts and wiring). Wiring seems easy enough, mainly between rear radar sensor and then couple of wires to zgm, power and ground. Mirrors I already found very cheap.
So I guess retrofit spree continues... |
| 03-20-2025, 02:07 PM | #3634 |
792
Rep 414
Installed camber adjustable front upper control arm's and did alignment.
ctcarbonari708.50 zrile184.50 |
| 03-22-2025, 11:29 AM | #3635 |
Semi-Feral Mechanic
175
Rep 192
Drives: 2012 BMW 535i xDrive
I recently did new struts and H&R lowering springs on the F10. I don’t have pictures after yet but soon. I need to replace my driver front cv axle now. I didn’t remove the axle bolts when I pushed the hub down so now it’s super sloppy. 154k on the clock so they needed done regardless.
You can live in a car but you can’t race a house.
| 03-22-2025, 06:17 PM | #3636 |
792
Rep 414
Maybe I should have made project thread of the F10. Anyways "accidentaly" ordered stuff for the 5AG now, I will also code 5AD since I have kafas.
| 03-23-2025, 05:28 AM | #3637 |
Rep 289
Drives: BMW 550i
Back to summer wheels
| 03-23-2025, 03:29 PM | #3638 |
792
Rep 414
Got the rear fuse box cleaned. Still need to buy one connector to get rid of last fuse hijacker and run all wires nicely.
Found the number for the connector, but seems like it's not easy to buy since, ETK does not know the part number at all: 61139225059 I probably have to buy rear fuse box with that connector in it. |
| 03-24-2025, 11:48 AM | #3639 |
Coal Troll
212
Rep 367
Decided to put on my summer wheels!
BBS CHR 20x9 et 24 (square) 3mm spacer F 5mm spacer R 255/35 H&R springs I couldnt be any happier with how it turned out! Need to get rid of that " Rays wheels" sticker..
My hybrid burns Diesel & Oil
deleted F15 |
9
StradaRedlands10085.00 cdmulders357.50 NikMN4383.00 Boarti9.00 zener791.50 Dtex535103.50 s_ribs134.50 poverty.f10175.00 zrile184.50 |
| 03-26-2025, 04:51 PM | #3641 |
Rep 6,273
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.03]
2007 BMW 328i [8.83] 2013 BMW X5 35i [8.43] 2009 BMW 328i Touri ... [8.50] 2011 BMW 528i [9.07] |
| 03-27-2025, 02:07 AM | #3642 |
Rep 6
Sure, here you go!
car needs to be lowered a bit i guess, but one step at a time lol |
| 03-27-2025, 11:50 PM | #3643 | |
![]() 1333
Rep 2,361
I really like those wheels but just couldn't find a set for my F11
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
| 03-28-2025, 02:20 AM | #3644 |
Rep 6
Those are Avus AC-MB3 in 19" 8,5 ET35, i guess you could mix em up with the styling 343/351 wheels.
Tire size is 245/40/19 i'll get you some sideways shots how they fit. They are legal in austria - so there is no rubbing, they are super strict over here ![]() Last edited by Boarti; 03-28-2025 at 05:24 AM.. |
| 03-28-2025, 05:16 AM | #3645 |
Rep 6
I suck at making pics lol
i hope they help you, otherwise i can take a couple more, there is alot of room, with spacers it would look more clean tbh probably will lower the car slightly with some springs ![]() Last edited by Boarti; 03-28-2025 at 05:21 AM.. Reason: added one more picture |
| 03-28-2025, 05:41 AM | #3646 |
792
Rep 414
5AD retofitted, vibrating feature did not work yet, let's see if anything changes after car gets to sleep. EDIT: had to code ICM and now it's fully working. Last edited by zener; 03-28-2025 at 07:29 AM.. |
Boarti9.00 StradaRedlands10085.00 |
| 03-28-2025, 02:11 PM | #3647 |
Rep 11
Some minor mods I've done to mine in the 2 months I've owned it.
- Black Front Bumper Trim - New foglights + LED bulbs - 15% "Midnight Black" Luminous Tint Next up are wheels and coilovers |
| 03-30-2025, 10:24 AM | #3648 |
792
Rep 414
Changed auto dim and blind spot side mirrors. As the mirrors where from blue car I painted covers black for now. I also ordered gloss black covers for them.
| 03-31-2025, 02:57 AM | #3649 |
Rep 6,273
Boarti9.00 |
| 03-31-2025, 05:31 PM | #3650 |
![]() 1484
Rep 2,684
Currently trying to install the pure600. Overall a VERY hard job, possibly one of the hardest jobs you can do short of engine removal. It's messy as shit and there's essentially no room to work.
Got the stock turbo out, but currently stuck at getting the turbo oil inlet line back on. It's a catch22 of a line - you can install the engine block side first, but then it's basically impossible to install it on the turbo. You can install it on the turbo first, but then it's impossible to get into the block. All this because BMW decided that the hold down bolt hole for that spot needs to be extremely unforgiving - if you're off my even half a degree, the threads don't line up and it's not possible to get it on. It's caused by the fact that the screw itself starts off almost completely square, meaning it can't come in off angle and have the threads correct the pitch. I have no idea why BMW decided to use such a difficult bolt design when the line is so short and essentially a hardline. Been struggling with this one line for 6+ hours now, about to give up and just buy a new line and see if that changes thing. All this while trying to fight a 20+lb turbo. You can't even install the turbo first and then worry about the line later - the diverter valve is right in front of the hold down screw, it's almost like a cruel joke by engineers to make fun of anyone who dares install a turbo with the engine inside the car. Any tips?
2015 BMW 535xi
StradaRedlands10085.00 windowmaker80.00 |
| 04-01-2025, 10:49 AM | #3651 |
Rep 6,273
Ugh, miserable. And I thought the coolant pipe bolts were bad... this sounds several degrees worse!
| 04-01-2025, 03:31 PM | #3652 | |
Rep 573
Drives: 2013 BMW F10 N55 535i XDrive
$ PURE STAGE 2 {} JORDAN CUSTOM TUNE {} DORCH HPFP {} SNOW METH {} DINAN EXHAUST {} EVOLV DARK OLIVE WRAP $ ![]() |
| Bookmarks |
| Thread Tools | |
