07-16-2024, 11:21 PM | #684 |
![]() ![]() ![]() ![]() ![]() ![]() 11641
Rep 45,108
Drives: 2018 Alpina B6 650ix GC
PM sent.
![]() 2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
07-21-2024, 04:21 AM | #685 |
Rep 3
HUD Not centered(or cut off) issue after CIC to NBT-Evo retrofit
![]() Hello. Recently, I retrofitted my F10 CIC to NBT-Evo through a private service provider. Everything seemed fine except that FM/AM radio reception isn't working. However, after driving the vehicle, I noticed an annoying issue with the HUD. The current speed is displayed correctly as before, and the radar trap warnings show up after the retrofit, but there is a problem where the image is cropped on the right side as shown in the pictures. I suspect that the image might be larger than the resolution that the HUD can display. For reference, the instrument cluster is of the 6WA type, and the HUD was not replaced. It would be great if this issue could be resolved through coding. I've checked the HU-NBT 2 module via E-sys, and it looks like there are options to select two types of resolution under HUD_AUFLOESUNG and something to modify under HUD_RES, but I can't figure out how to proceed. I think it might also be worth looking into the KOMBI settings, but I have no idea where to start. I would appreciate your help! |
07-21-2024, 12:12 PM | #686 | |
Rep 45,108
For Radio, the problem is that NBT2 does not put out a 'radio on' signal on pin 13, CIC does. The radio on signal is used by cars without NBT2 to power the amplifier, and diversity antenna. If you are retrofitting NBT, and your prior headunit was putting out a radio on signal on pin 13, you need to send power on pin 13 on the car side. The easiest way is to connect pin 13 on the harness/car side to pin 15. Pin 15 is powered with the ignition, so your amplifier, and diversity antenna will be powered whenever the ignition is on.
08-06-2024, 07:00 PM | #687 |
Rep 5
Hey i have a bmw f10 2012 can someone send me a link to download a newer version of the software (europe based)
And can someone tell me how should i install it on the system to make the update |
08-19-2024, 02:01 PM | #688 |
![]() 0
Rep 7
Hello guys. Would like to know if someone did coding for steering wheel buttons to change engine mode? Have M5 steering wheel with M1/M2 buttons and would like to know if it is posible to do M1 up M2 down like switch on console do?
08-23-2024, 11:37 AM | #689 |
Rep 1
Hello guys. I have 2 questions.The right headlights do not work at all, only the signals work. When I look at ista, FRM also shows an error. How can I fix this or clear the error? And even though I renewed the pedestrian protection system after the accident, ACSM also shows an error. How can I delete this or what is the solution?
09-02-2024, 03:39 AM | #690 |
![]() 24
Rep 175
hey shawnsheridan
11' 530D Can I get the link for ista d and psdzdata? looking forward to retrofit nbt from cic and new eBay afs headlights replacements (do I need to code this?). future is f10 surround view and led lci headlights. |
09-02-2024, 09:41 AM | #691 |
Rep 45,108
Thread has nothing to do with ISTA. I know nothing about using Aftermarket Headlights. PM sent.
09-04-2024, 10:51 PM | #692 |
![]() 24
Rep 175
09-05-2024, 01:18 AM | #693 |
Rep 45,108
Thread is Coding. ISTA isn't as it is Diagnosis and Programming.
09-05-2024, 05:22 PM | #694 |
Rep 2
Cornering Malfunction Errors Coded Out
I bought a different set of headlights that do not have these features. I don't need them so I coded them out. If anyone else would like to coded out. Here is the info. Also, I used BIMMERCODE to get these done. |
12-18-2024, 12:27 PM | #696 |
Rep 3
n20 timing chain replacement
hey guys i,m new here and im prepping for a n20 timing chain replacement and im asking if i can be sent a link for ista so i can input flow rate and other things for the n20
12-18-2024, 12:55 PM | #697 |
Rep 45,108
Your PM function is disabled. Send one when enabled.
12-19-2024, 04:00 PM | #698 |
Rep 1
Hi, I have a BMW 2011 535i XDrive (think it is F10) and it has valvetronic error code. I installed BMX coding Tool on my pc and SP Daten folder "F010" but it will not let me input this as daten source. I have cable and ISTA+ and I would like to run the valvetronic reset on it as is recommended. Any pointers as to why the coding tool app will not take it as source, it takes the "Base" folder fine and updates it.
12-19-2024, 04:15 PM | #699 | |
Rep 45,108
12-30-2024, 02:18 PM | #701 |
Rep 45,108
PM sent.
01-05-2025, 04:30 AM | #702 |
![]() 0
Rep 1
01-05-2025, 11:00 AM | #703 |
Rep 45,108
01-23-2025, 10:32 AM | #704 |
Rep 5
Hi, I've been trying to update maps on my F11 and when I connect with Esys it shows as HU_ENTRYNAV, nothing to download on 1B or DE application but DF does produce a FSC file attached. But it is not clear what to do next as the FSC generator expects a 1B (CIC), DE (NBT) or F0 (EVO) and I'm not sure what HU_ENTRYNAV counts as.
Vin ending D788978 Alan |
