09-22-2019, 11:25 AM | #1 |
Rep 85
2016 F10 N55 build
Getting ready to start ordering some parts. thinking wagner catted dp, wagner intercooler and JB4.. target is about ~400hp at the wheels. I want to make sure I have reliable hp as this is a daily driver. anyone have thoughts on this setup/experience with wagner parts?
09-22-2019, 11:05 PM | #2 |
Rep 332
I have the Wagner IC and it's a great product, but right now there are a lot of cheaper alternatives and I think I would go that route. 3 years ago when I built my car there was no other option.
2022 G82 M4 - Isle of Man Green w/Kyalami Carbon Bucket Seats - MST Intakes, SSR Downpipes, JB4, AWE Exhaust.
2013 F10 N55 (535i), Pure Stage 2, Fuel-It PI Platinum, Fuel-It Stage 2 LPFP, BootMod3, Custom Turbo Inlet, Custom Cary Jordan Tune, More.. SOLD! 1999 e36 M3 - Estoril Blue - Track Car - S54 Swapped |
CommoN8149.00 |
09-23-2019, 05:31 PM | #4 |
Rep 332
https://f10.5post.com/forums/showthread.php?t=1585080 I also wouldn't do a catted DP if you are going to replace it.
CommoN8149.00 Bmw doubles983.50 |
09-23-2019, 06:19 PM | #5 | |
Rep 1,442
Drives: 2011 535i 6MT
I did a write up on my install of this IC as well and supposedly there is zero detectable difference between this one and the wagner. For 400 WHP you'll need to do mhd stage 2+ and I'd skip the JB4. Just look up what you need for stage 2+ and you are done. |
CommoN8149.00 |
09-24-2019, 12:34 AM | #7 | |
Rep 21
CommoN8149.00 |
09-24-2019, 02:58 AM | #8 | ||
Rep 590
CommoN8149.00 |
09-24-2019, 08:24 AM | #9 |
Rep 2,590
Because some people like MHD. BM3 is definitely less convenient, since you have to buy an expensive WiFi agent or DIY one (pretty easy though) in order to use your phone. MHD was designed for mobile use from the get go.
Personally I use and prefer BM3. The WiFi agent is very cheap and simple to make, BM3 provides their WiFi agent image for free, and the only cable you need is an ENET cable. Also, definitely invest in an aftermarket charge pipe. ER makes a good one and is what I use. There's been stories about people's charge pipes popping from the increased boost. It's a lot more of a preventative maintenance mod, but why run the risk? |
CommoN8149.00 |
09-24-2019, 01:05 PM | #10 | |
Rep 688
2014 Carbon Black 535i M Sport - Bootmod3 / M Performance Exhaust / Carbon Graphite Vorsteiner V-FF 103 / KW V2
Retired- 2013 MG 328i Sport Line 6MT - BMS Stage 1 / M Performance exhaust / M Performance steering wheel / M Performance shift knob/boot |
CommoN8149.00 |
09-24-2019, 01:54 PM | #12 | |
Rep 2,590
Just make sure to run your first tune after a nice long drive so the battery is full charged if you don't have a battery charger/tender. The first tune takes a while because it needs to unlock the DME. Stage 2 is where you need a downpipe, IC, and charge pipe. |
ThaiBruin170.50 |
09-24-2019, 04:33 PM | #13 | |
Rep 85
Thanks for all the replies and info, helps with my research. Was planning on upgrading the charge pipe too once I was putting everything on. Will look into the BM3 some more. |
09-24-2019, 07:27 PM | #14 |
Rep 5,362
09-24-2019, 07:33 PM | #15 |
Rep 688
09-24-2019, 11:12 PM | #19 |
Rep 5,362
Yup. ANY change to the intake and exhaust until the cats is a fail; UNLESS the part has a CARB certification sticker. The guy that did the smog check on our 2012 spent around 5 minutes searching under the hood.
09-25-2019, 01:05 PM | #20 |
Rep 1,442
In TN they only do a visual... and they have no idea what they are looking for, and check for engine readiness through the computer. I had no issues with a catless DP and simply using a tune or other methods to get my OBDII to read OK for the readiness check... all depends on WHAT kind of inspection/smog check they do in your local area.
09-26-2019, 06:33 PM | #21 |
Rep 1,299
They only plug obdii and check for emission... I passed so far twice with Catless downpipe.
Bmw doubles983.50 |
09-29-2019, 10:22 PM | #22 |
Rep 688
Just came back from a trip and flashed my car with BM3 Stage 1 OTS (91 octane, boooo California). This is by far the best tune I've used so far. I've had a JB4, a Dinantronics Sport Tuner, and this is the best of em all. Absolutely no peaky (sometimes unpredictable) power boosts, and just a lot more oompf throughout the powerband.
The only thing that I'm trying to figure out is burbles. I can't seem to hear any, and it was my understanding that you'd still get burbles even without any additional mods. I do have an M Performance exhaust, but nothing else.
