2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Jb4 550Xi - no real power difference?
      12-29-2017, 08:06 AM   #1
Hilly
Drives: 2011 550xi m-sport
Not sure if it is just me, I bought the JB4 beta without the BCM. When switching from stock to maps 1 and 2 even...I do not feel a huge difference in power when compared to the e90 335i I use to drive where the difference is instant. Everything on the steering wheel seems to work etc, is it just me or does anyone think I might have to re-check the wires etc? I do not have the JB4 connect kit so I might have to invest in that to really see whats going on I guess
I drive a 2011 550xi
      01-01-2018, 01:54 PM   #2
$howtime456
$howtime456's Avatar
301
Drives: BMW 640i
do you have FBO? If not your not going to feel a huge difference.
N55 GENERAL
David Shoup Tuned
Fully Built By Miami Engines/Project Motorworks
Precision 6266 On Steroids
      01-02-2018, 11:08 AM   #3
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
Not a huge difference from Map 1 to Map 2?
      01-03-2018, 03:41 PM   #4
Hilly
Not FBO - just tune. I figured being that the car is so heavy and big, the power wouldn't be felt as such. However, I did order the BCM cable as well at the JB4 connect...so as soon as all of this is installed we will see
      02-12-2018, 12:57 PM   #5
535_BiTurbo
updates?
      02-12-2018, 04:09 PM   #6
Hilly
Originally Posted by 535_BiTurbo View Post
updates?
Huge difference from Map 2 to Map 7 (with BCM connected). The JB4 connect kit is also a cool little feature...I can see exactly if I am hitting the correct boost, timing etc
I had a 335i before and when I put a tune on it you could really feel the difference. With the 550i I didn't feel that much of a difference as I stated before. But going to the BCM and map 7 is similar to that feeling I got with the 335i
      02-12-2018, 04:28 PM   #7
535_BiTurbo
Did you throw any codes?
      02-13-2018, 08:49 AM   #8
Hilly
Only had to get one injector replaced due to misfire. Other than that running well
      02-13-2018, 02:31 PM   #9
BlackWidow
Drives: M5
Map 2 is just a few psi over stock, map 7 is where the power is.
      02-13-2018, 03:45 PM   #10
535_BiTurbo
Do you have to have downpipes to run Map 7?
      02-13-2018, 04:14 PM   #11
Zer0Cool92
Drives: blue metallic
What power does map 7 make ?
      02-13-2018, 11:37 PM   #12
BlackWidow
Drives: M5
No, dont fall into the hype of catless dp's. The stock downpipes are more than enough for the power that can be currently made with the N63. Until a flash tune is readily available, catless dp's dont do anything but help the turbos spool faster which should give you a small bump in the mid power range. You would worry about the transmission before anything else.
8 psi over stock and it requires the BCM
BMS Dyno proved to be around 500whp/560tq and its more reliable than the old bms stage 2. Car is night and day between map 0-2 and map 7 with bcm and high octane fuel to prevent preignition.
      02-14-2018, 01:00 AM   #13
535_BiTurbo
As I recalled reading in the past, F10 550i JB4 Beta Map 1 is about equal to N63 BMS stage 1, so I figure about ~420-430rwhp. Then Map 2 is 2psi more than Map 1 which is equal to the old N63 BMS stage 2 numbers of ~460-470rwhp. Then Map 7 is 2psi more than Map 2, and BMS has gotten ~ 500-510rwhp.
      02-14-2018, 07:21 AM   #14
Milestune
How many miles on your car, Hilly?
      02-14-2018, 08:16 AM   #15
Hilly
Around 39K right now
      02-14-2018, 08:17 AM   #16
Hilly
I'm curious that if we swap the TMAP to 3.5 if we can see the same results as with the N63tu (or close to it)....that would be the next thing I would look at doing
      02-14-2018, 09:19 AM   #17
535_BiTurbo
Terry mentioned something about the twin bank control, the N63 is limited to 19-20psi tops and the TU is 24-25psi tops
      02-15-2018, 10:25 AM   #18
BlackWidow
Drives: M5
I think it’s right around the numbers of the old systems, BMS Stage 2 didn’t add much out of the box. The numbers 460-470 for BMS Stage 2 that were initially advertised by BMS were higher than what was actually released. Their product car hit those numbers and it was initially what they wanted but the tune wasn’t stable for public release. This is why I cranked my BSF up after my first few drives with the Stage 2.
      02-15-2018, 04:17 PM   #19
S1ammin
Drives: 2013 BMW 535i MSport
Swapping the TMAP to 3.5 won't get you more HP. It would allow you to read higher boost that you would get if you upgraded the turbos though since I think the stock TMAP can't read more than 21 or so PSI. At least this is my understanding.
      02-15-2018, 04:18 PM   #20
Hilly
right - allow for higher boost = more power.
      02-15-2018, 04:24 PM   #21
S1ammin
Wow, that would be a sweet upgrade if the JB4 pushes stock turbos high enough to require the swap. I'm really not familiar enough to know though. Glad you got yours straightened out. I know it's a beast!
      02-15-2018, 11:34 PM   #22
535_BiTurbo
BSF??
