2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions aftermarket rear diffuser for 2015 535xi M-sport and comfort access trunk opening
      11-12-2018, 08:44 AM   #1
dzz
Drives: 2015 BMW 535xi, MHD Stage 2+
2015 BMW  [0.00]
All,
I've purchased this rear diffuser https://www.ecstuning.com/b-ecs-part...s/011818ecs01/ which accroding to ECS website should fit my car. Unfortunately comfort access trunk opening sensors (opening the trunk using your foot) and TPMS module are in the way. While I can relocate TPMS module, there is no way to keep comfort access trunk opening sensors if I want to use this rear diffuser.
Has anyone installed rear diffuser with aggressive look (similar to M5) that can accomodate quad exhaust tips on their car and was able to keep comfort access trunk opening sensors in place and working?
Thank you for your help.
      11-12-2018, 12:01 PM   #2
Originally Posted by dzz View Post
All,
Just because it fits doesn't mean it's the correct one; as in your case. You need one that accommodates Comfort Access.
      11-12-2018, 06:00 PM   #3
dzz
2015 BMW  [0.00]
Do you know which aftermarket diffuser can accommodate comfort access?
      11-12-2018, 06:14 PM   #4
MOBF10
MOBF10's Avatar
171
Drives: 2018 M3 Comp
You'll need to buy the adapter that is listed in this post in order to keep your comfort access without having to cut anything up and relocate the parts.
https://f10.5post.com/forums/showthr...ensor+diffuser
      11-12-2018, 06:15 PM   #5
MOBF10
MOBF10's Avatar
171
the adapter is only $40 here
https://www.getbmwparts.com/oem-part...er-51128053585
      11-13-2018, 09:22 AM   #6
dzz
2015 BMW  [0.00]
Originally Posted by MOBF10 View Post
Thank you MOBF10 !!! I have ordered the part, I'll let you know how it goes.
      11-13-2018, 01:12 PM   #7
MOBF10
MOBF10's Avatar
171
No problem
      01-13-2019, 06:17 PM   #8
dzz
2015 BMW  [0.00]
just an update that https://www.ecstuning.com/b-ecs-part...s/011818ecs01/ with https://www.getbmwparts.com/oem-part...er-51128053585 adapter that MOBF10 reccomended, allows that trunk comfort access is working on a 535 with M-sport bumper
      02-01-2019, 09:17 PM   #9
chmsalman
chmsalman's Avatar
Drives: 2014 F10 535i x-drive
Interesting! I was having the same issue but just let it be. Is it the absorber that I need? What does it do? Where does it sit? How do I install it? hahah
$40 to make the sensor work again is totally worth it. Help!
      02-06-2019, 10:39 AM   #10
docjavier
docjavier's Avatar
Spain
1108
Drives: G80 M3 F10 535i
I did this upgrade on my 2012 M sport 535i using the adapter. the diffuser and adapter installed with no problem, but I could not make the sensor work. I also will like to know where are people putting their sensor for it to work?
I zipped tied it perpendicular to the ground and it does not work that way.
2023 G80 M3 C/XD SMB, 2012 F10 535i M-Sport, BM3 stage 2. 2014 Porsche Cayenne GTS.
      03-15-2019, 02:30 AM   #11
SoCal550
Drives: BMW 550i
Do you have pics of this installed ? I am contemplating making the same purchase from ECS as well as the adapter .
