2010 2011 BMW 5 Series Forum F10 Compiling some F10 535 sway bar info |
10-19-2020, 12:23 PM | #1 |
Rep 441
Thanks to all the folks that helped me in the other thread. This is my first foray into suspension stuff so I’ve been doing a lot of searching...I had to piece together a bunch of info on sways from a bunch of threads and also had to call H&R and Eibach to confirm stuff, so thought I’d try to give back a bit and compile it all here. If this muddies the waters with any contentious info lmk and I’ll correct it or edit it out.
Thickness Stock: 24mm front/14mm rear M5 front: 29mm at the ends, but 26mm in the middle 650i rear: 16mm (M5 rear doesn’t fit, so people that are using OEM to upgrade use M5 front + 650 rear) Eibach and H&R: 30mm front/20mm rear Xdrive vs. RWD Confusing because Eibach and H&R only list RWD as compatible. I called both, they said that it probably means they haven’t tested an xdrive but there’s nothing about AWD that means they need special sways as long as the RWD versions fit. Countless comments from people here saying all the above bars fit on either RWD or xdrive. H&R at ~$650 vs. Eibach at ~$450 Seem identical - same thickness, from what I can tell neither are “adjustable” (multiple mounting holes). My best guess at price difference is because H&R made in Germany and Eibach made in USA. Install Unlike F30, very straightforward (a “no-brainer” to some). Supposedly much easier if suspension is unloaded at least a couple inches and, in the rear, if the exhaust is taken down from hangers and a bolt removed (thanks Sylverlee, below). I’ll update after I put my Eibachs on in a week or two. Torque specs I’ve found: Front end link: 75-90 ft lbs range but nothing exact (or 65 nM per n3985, below) Rear end link: 30 ft lbs Bushing mounts: 16 ft lbs Feedback Seems that Eibach and H&R are very stiff - too stiff for some folks' DDs - and the M5/650i might be a better middle ground for those who still want some DD comfort. Myself, I'm excited for my Eibachs to arrive because I don't have a long commute where I need that kind of comfort.
2013 535xi M Sport (PWG) // PS2 // Spool fx150 // MHD // xHP // FTP Inlet // FBO: AR HF DP, Wagner IC, BMS Intake, VRSF CP
10-19-2020, 01:22 PM | #2 |
Rep 538
Perfect, thanks for putting this together. I've been considering the Eibachs as well. I'll be interested to see how you feel. Every bit I've feedback I've seen, they really make a difference.
'16 Carbon Black Metallic F10 535i M-Sport - TOTALED 11/21/21 '13 Black Sapphire Metallic F30 335i M-Sport - unknown charge pipe, MSport Exhaust, 20" 405M wheels, $61k MSRP, CF M4 Mirror caps & Spoiler, NGK plugs, Dinan Coils, BMS intake |
10-19-2020, 02:43 PM | #4 |
Rep 441
Like, just detaching where it hangs?
10-19-2020, 03:27 PM | #6 |
Rep 598
The Eibach sway bars are not adjustable but are xDrive compatible.
Front end link should 65 nM Also be wary of anyone complaining their sway bars made the car "too stiff". Sway bars affect side to side weight transfer not the efficacy of the shocks and springs. Low chance they didn't install the end link with suspension loaded and high chance they are correlating wrong sensation to cause. |
10-19-2020, 03:32 PM | #7 | |
Rep 441
https://f10.5post.com/forums/showthread.php?t=1139411
10-19-2020, 03:34 PM | #8 | |
Rep 598
EV8634.00 |
10-19-2020, 03:37 PM | #9 |
Rep 441
I didn't get the impression it was wrong only because it took extra torque to remove them...I've seen that 70-90 ft lbs listed a few times by others but no real source given. Sucks newtis is down. Where did you get 65 nM?
10-19-2020, 03:41 PM | #10 |
Rep 598
65 nM has been the standard BMW torque spec for front end links since E30.
10-20-2020, 07:29 AM | #11 | |
Rep 1,873
With stock X-Drive non-adaptive suspension and the 30mm front bar, I observed rocking oscillations in every day driving conditions (eg. imperfect pavement, turning right into a store driveway where left/right front wheels drive over the cut curb at different times) and other evidence of left/right being tied together too tightly. My head would be bobbled rapidly left/right every time I pulled into the grocery store parking lot. The suspension was "bouncing off the bars" too much (for my taste anyways, and I like a firm car). It actually detracted from perceived performance. The rear 20mm bar causes no detriments and I left it on, but I made a step back in firmness to the M5 front bar. This combination substantially improved balance too, dialing things more towards neutral. Now, that being said, I have not put the 30mm front bar on for a test drive since I put my coilovers on this summer. With tighter coilover suspension helping with body control from the outset those side-to-side oscillations may never start. I've read lots of comments from folks who feel no need for any sway bar upgrade of any kind after fitting coilovers. If you're fitting these largest bars (30/20) to non-factory suspension that is stiffer, you might not notice any of the negative things I've mentioned since your car is tighter from the outset. Why I did not rush out and reinstall the 30mm front bar - since I put the coilovers on I've observed more understeer if anything (but only in some conditions - I could write a whole long post just on this). If I stiffen the front more it will make any understeer I'm observing worse. I wanted to do a big swap party one weekend and figure things out to balance the car best but haven't been driving all that much and there's always been other things more important to do. TBH, I'm also a little concerned about manufacturer insistence by both H&R and Eibach (at least at the time that I purchased) that they are NOT for X-Drive cars. They seem to fit fine, but I have this nagging feeling that maybe they know something consumers don't know and perhaps on the X-Drive front suspension under high load the front bars have caused some kind of damage or make contact with something they shouldn't under high load. Not sure on that, just a feeling, and at my age those feelings sometimes prove to be right. If they could sell the same product to more people why wouldn't they? At any rate, I own pretty much all the combinations of bars that fit this chassis and I've tried them all at some point. One day I'll settle down, pick a set and sell the rest. |
John H.230.00 |
10-20-2020, 08:03 AM | #12 | ||
Rep 598
Everyone have different levels of sensitivity to NVH therefore caveat emptor is the suggested mentality for modifications. |
10-20-2020, 12:02 PM | #13 | |
Rep 441
A guy I talked to at H&R said he and a coworker tried to put e90 RWD sways on the coworker's e90 xdrive...they couldn't because the sways didn't fit, and he seemed to have the similar shrug of "but if they did fit, I guess it's fine right?" Maybe they don't think there's much of a 5 series xdrive grocery getter market for sways to make it worth testing? But weird for both Eibach and H&R to not list xdrive. Who knows. FWIW ECS lists them fitting a bazillion F series models, but that doesn't mean they're harmless: https://www.ecstuning.com/b-eibach-p...-20-022-01-11/
10-20-2020, 02:15 PM | #14 |
Rep 965
[QUOTE=Surly73;26818917]
The suspension was "bouncing off the bars" too much (for my taste anyways, and I like a firm car). It actually detracted from perceived performance. The rear 20mm bar causes no detriments and I left it on, but I made a step back in firmness to the M5 front bar. This combination substantially improved balance too, dialing things more towards neutral. Same. H&R felt "stiff" in the sense that every road imperfection sent turbulence through the cabin and steering wheel. Had it without coilovers, and then with coilovers. I run a 16mm 650i x-drive sway bar in the rear now. Would be interested in picking up a 20mm if someone ever sold it separately at a decent price. |
10-20-2020, 04:01 PM | #15 | |
Rep 1,873
I'm also thinking about trying the original front bar for balance reasons though. I wonder how much of the lean would be taken out by just the KWs. |
10-20-2020, 04:17 PM | #16 |
Rep 232
In my experience, the Eibach bars are so stiff that independent suspension action is comprised. A pot hole on the left front would shake both sides of the car on Chicago's bad winter roads. The M5 bars were better, but still too stiff. I am now running KW V3s with the stock bars and the car is wonderful.
Good luck. |
10-26-2020, 12:23 PM | #17 |
Rep 441
Put my Eibachs on over the weekend. Easy access to everything (as expected) and was easy to snake the bars in/out of place without having to move anything else (bit of a pleasant surprise, at least for the rear bar).
The only surprise is I nearly lost an hour - an hour filled with annoyance and anxiety - dealing with the rear bar's bushing brackets. The brackets really didn't want to fit around the bushings, so bad that I thought they gave me the wrong bushings as first. I had all sorts of clamps trying to get the bushing seated deep enough into the bracket and then also pinching the bracket together sideways because the bracket bolt holes were lining up a good 1/2" or so too wide. A long process of clamping and alternating the tightening of the front/back bolts until I finally got it lined up and in there. Scary because it was a situation ripe for cross threading but luckily all's well that ends well. Doing it again, I would try clamping them bushings in there both direction and letting the clamps settle in for some time before going to mount the bar. The front bar brackets are heavier duty and I was able to get the bushings into the mounts by hand and the holes lined right up also because, unlike the rear, the heavier duty brackets didn't flex to stretch for the bushings at all. After all the torque spec back and forth I realized the point others made that it's heavy duty hardware and you just need to give it hell and do the ol "guttentight."
10-26-2020, 12:38 PM | #18 |
Rep 1,442
Drives: 2011 535i 6MT
My 2 cents: I did H&R's and they were not 650, I think I paid 400?
I like them - Stiff ride for the win!!!! |
10-26-2020, 12:47 PM | #19 |
Rep 441
Yea looked like some of you guys got a helluva deal from that website, even they had them listed for about $600 now I think and that was the lowest I've seen. Eibachs from tirerack arrived pretty quick for $455.
10-29-2020, 03:05 PM | #20 |
Rep 965
What did you tighten the end links to? Was so hard for me to get a wrench in there, I had to use a small automatic wrench that prob only got me 20lbs.. feels firm though.
10-29-2020, 03:44 PM | #21 | |
Rep 441
10-29-2020, 04:21 PM | #22 |
Rep 965
