07-08-2014, 08:40 AM | #45 |
Rep 149
Drives: M3 E92 with AA Stage 3 SC
07-08-2014, 11:02 AM | #46 | |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
09-22-2014, 12:42 PM | #47 |
Rep 980
Ok so I finally installed these beauties and snapped a few pics before they went in.
Nitron NTR R3 Triple Adjustable Coilovers - I will add pertinent info later, need to find the owner's manual! Front Spring Rates: Custom but I chose 600lb linear springs Rear Spring Rates: Custom but I chose 800lb linear spring Triple Adjustable Settings: High and Low Speed Compression and Low Speed Rebound Front and Rear: Front Only: Rear Only Rear Top Pillowball attachment: Camber Plates: |
09-22-2014, 01:45 PM | #48 |
Rep 86
12-05-2014, 01:14 AM | #49 |
Rep 356
Status Gruppe Manufacturing
The 2007-13 BMW E90/92/93 M3 SGT-SRS coilover features: * Pillow-ball camber plates (Dual bearing design to reduce noise) * Machined aluminum RSMs * 18 way adjustable dampening (combination of rebound and compression) * Monotube gas charge dampers * High strength anodized aluminum alloy and powder coated steel components * Full length height adjustment with separate settings for damper force and spring pre-tension * Linear race springs 8kg front / 10kg rear (Cold wound from high tensile chromium silicone wire) * SGT Adjustable Sway bar endlinks * SWIFT Race Spring (Optional Upgrade) Pricing $1425-1800 |
Kelse921132.50 |
12-05-2014, 08:32 PM | #50 | |
Rep 386
12-10-2014, 01:19 AM | #51 | |
SLOOM3
18
Rep 37
Drives: 2011 M3 DCT, 2015 F80 M3 DCT
KW Adjustable Spring Conversion or "HAS" (Height Adjustable Springs)
If you would like to keep your EDC system/shocks but want to lower your M3, you can purchase the KW Adjustable Spring Conversion or "HAS" (Height Adjustable Springs). This kit will lower the front and rear of the car while allowing you to keep your EDC functional. I just purchased a set and once my EDC's start to wear out, I'll purchase a full Coilover system. For now, it's the most affordable way to go and plus it's made by KW so you know it's a great product. http://www.**********s.com/KW-Adjust...E92-E93-M3.htm Enjoy |
07-21-2019, 10:59 AM | #55 |
Rep 38
Intrax 1K2
http://en.intraxracing.nl/producten/1k2/ Not sure about technical specs but they are very customisable. |
08-16-2019, 10:20 AM | #56 |
Rep 370
Anyone have any information about E90/92/93 stock Edc/NON Edc spring rates?
08-28-2020, 09:50 AM | #57 | |
Rep 6
My question is (and I have spent hours looking for this information) what are the spring rates for the ZCP springs? I am actually really surprised no one has listed this to date (unless it was my lack of searching skills). We know there are springs listed X6 and X5..so can we work to fill out the ZCP spring rates as a baseline for anyone looking to go with non-oem vendors both in coilovers and spring sets? Does anyone have this information. ZCP: Front Spring Rate: (Labeled M3/X6) Rear Spring Rate: (Labeled M3/X5) |
