2010 2011 BMW 5 Series Forum F10 Serpentine belt snapped- belt got in engine |
02-20-2019, 03:01 PM | #1 |
Rep 205
So I was visiting my family in FL over the weekend when my dash lit up like Christmas. Before I could pull over the car said the engine was overheating so I coasted in N over to the shoulder. Popped the hood, belt was gone. Just remnants of belt that looked like black chunks of cotton. I had the car towed to a shop my family uses and had the tensioner and belt replaced using OEM parts. Everything else checked out (supposedly) but they couldn't clear the faults the ECU threw.
So I drove home the next day (2 hours away) keeping an eye on the temps, oil level, and trying to listen for any odd sounds. Nothing funky until 10 minutes from home. Slight shake while at a red light. "Ok. It's idling a little rough now. I'm taking it to the dealer tomorrow to get looked at." Dealer ran their diagnostics and came back with a lovey list of needed repairs for immediate attention because my belt was sucked into the engine. OFHG, Crankshaft Seal, oil pan gasket, and valve cover gasket. For a proper repair, does that sound right? They stated they could see belt fragments when the opened the oil cap?? They are asking for nearly $5k. Thoughts? [IMG][/IMG] |
02-20-2019, 04:20 PM | #2 |
Rep 5
Run fast and run far!! That sounds like a load of BS. Just how does the belt get inside the crankcase? Is it actually leaking oil? Similar thing happened to me when I took my Mini (BMW) in for a recall, they quoted my over $3,000 for needed repairs! By the way , it's a 2002 Cooper with a book value of less than $4,000. Find a good independent shop to get the codes cleared and checked out.
That's why they are called Stealerships! |
02-20-2019, 04:42 PM | #3 |
Rep 332
I know this is common on N54's, but wasn't sure on N55's. This is the reason if you have a leaking OFHG it needs to be dealt with immediately. If not, oil gets on the belt it will destroy the engine.
2022 G82 M4 - Isle of Man Green w/Kyalami Carbon Bucket Seats - MST Intakes, SSR Downpipes, JB4, AWE Exhaust.
2013 F10 N55 (535i), Pure Stage 2, Fuel-It PI Platinum, Fuel-It Stage 2 LPFP, BootMod3, Custom Turbo Inlet, Custom Cary Jordan Tune, More.. SOLD! 1999 e36 M3 - Estoril Blue - Track Car - S54 Swapped |
02-20-2019, 05:31 PM | #4 |
Rep 205
Crazy part is, it was such a minor leak. Dealer even said "it's something I would plan to do in the next few months for sure, but not urgent as of now". I honestly think with 83k miles it was just worn out. PO definitely drove it "spirited"
02-21-2019, 07:00 AM | #5 |
Rep 1,873
There was a thead here or one of the other F10 boards about this just a month or two ago. We all had to get over our "belt sucked into the engine? - BS!" stance because it can and does happen, apparently.
Still shocked, but you're the second thread in a couple of months. I think it depends on just how the tensioner lets go. Maybe I should be scheduling some extra PM on the belt system that doesn't seem required.... |
02-21-2019, 07:31 AM | #6 | |
Rep 205
02-24-2019, 09:29 PM | #7 |
Rep 5,691
It’s not bs, we’ve had a handful of cars do this. They are opening up your engine to remove all the belts fragments that are going to destroy your engine. It needs to be done immediately.
02-24-2019, 09:33 PM | #8 |
Rep 205
I'm
I definitely do not feel like chancing it. It just sucks that the cost was so high. Car is parked until I can open it up this coming weekend. Any tips for a DIYer?
02-26-2019, 02:17 PM | #9 |
Rep 14,521
Soon as I found out my oil filter gasket housing was leaking I got the repair done ASAP because I did not want a costly repair. Should've gotten it done when you were told
02-27-2019, 10:10 PM | #10 |
Rep 5,691
You are going to do it yourself? Good luck man. I would not do it unless you are super well mechanically inclined. Also you will need special tools for crank seal.
02-27-2019, 10:16 PM | #11 |
Rep 205
So I did have the dealer do the crank seal since I've never done that before nor have the tool for it. OFHG and Oil Pan tho shouldn't be hard, just time consuming. Luckily i'm not doing it alone. My brother in law is a mechanic. Fingers crossed for a smooth endeavor.
03-01-2019, 11:31 AM | #12 |
Rep 342
Sorry, sounds like BS to me. Does not pass the smell test. How can fragments of the belt get into the engine uness it tore up the intake pipes, valve cover, etc? It is a sealed system for emissions control. I can possibly see the crankshaft end seal getting damaged (even skeptical on this.). Yes it makes a mess when a belt goes, just go through the engine compartment with a shop vac and air hose to get the crap out... clean the motor with engine degreaser and hose it down then see of you have any leaks and fix them.
03-01-2019, 11:37 AM | #13 | |
Rep 205
Edit: I found this awesome write-up on this issue and fixing the shit show. https://www.e90post.com/forums/showt...0#post20582508 |
03-01-2019, 08:08 PM | #14 | |
Rep 342
People need to pop their hoods more often and be more observant. This didnt happen in one trip. When my belt went bad it was due to the lower pulley hitting the frame and cracking an edge off. This gradually chewed the side of the belt away causing rubber and thread fuzz to scatter around the engine compartment. I saw the crap all over the front of the engine and started investigating. Found half the width of the belt gone and the broken pully. Cleaned it up, replaced the broken pulley, idler, tensioner, belt, etc. and didn't have any more issues. |
03-02-2019, 06:52 PM | #15 | |
Rep 267
N54 r notorious for this. And for n55 this isnt very uncommon. Oil gets on belt. Belt slips and shreds. Gets sucked into crank then into engine. This is why ofhg is a MUST repair and it needs immediate attention. |
03-03-2019, 08:02 AM | #16 | |
Rep 5,691
03-03-2019, 08:06 AM | #17 | |
Rep 5,691
03-04-2019, 07:43 AM | #18 | ||
Rep 205
I see why they charge over $1k for this job |
03-10-2019, 11:26 AM | #19 |
Rep 205
Quick update. After searching and searching for a way to get the subframe to drop enough to get the pan out all way, I jacked the motor up some to be able to see in the pan and get the pickup tube off. Glad I did as there sure enough was about 8 inches worth of belt still in the pan and the pickup tube was almost clogged up completely. Cleaned out the pickup tube with parts cleaner and compressed air, cleaned out the pan, and am in the process of putting it all back together.
BurrNinja431.50 |
03-15-2019, 06:22 AM | #20 |
Rep 176
Oh this is really bad ! Thanks for sharing, I just checked mine and it seems to be leaking badly. I will get an appointment to do the gasket, belts and maybe tentionner at the same time ASAP! I hope my Indy will not charge me too much for that !
Anything else I should check or replace while I am at it? My car is a 2011 at around 118k KM never done any major maintenance ( only oil changes, brake fluide ...)
BMW 535I xdrive 2011 M-Sport with H&R Springs, Niche Form Wheels 8.5 ET35 / 10.5 ET35, Continental DSW06 245/35 & 285/30, JB4 Map 5, ER Downpipe, Megan Racing Quad Exhaust with Vibrant resonators, M5 Diffuser, Orange reflector shaved and removed xdrive badge.
03-15-2019, 06:28 AM | #21 |
Rep 205
If it's your OFHG, it honestly isn't hard to do at all. The most important part is making sure to A) thoroughly clean the area where the gaskets go, & B) make sure to tighten all the bolts to spec. I was nervous about break a bolt I under-tightened and had a leak when I turned the car on. Tightened it up, and good to go
