2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum 535i reliability?
      02-09-2025, 02:24 PM   #23
BrandonKH
BrandonKH's Avatar
Drives: 2016 535i Xdrive
Originally Posted by Carbon535i View Post
With alot of work you have already did you almost covered most of the major areas. I have a 2015 535i xDrive and have been in the same boat as the previous owner totally did a number to it and neglected maintenance while also "clapping" it out, so over the last 9 months I had it on jack stands and overhauling it. When you change your oil pan gasket, I recommend replacing the rod bearings and when you do the valve cover, replace the oil filter housing gasket. I would keep it as most of everything has been addressed.
Yeah I mean I feel like I’ve covered a lot but I’m thinking about like valvetronic failure and water pump + electrical, ac kompressor and more control arm issues as well. Since I’ve spent so much already I’m kinda feeling like I shouldn’t take any more chances. Especially with all the possibilities.
