2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding MMI Carbox (Carplay, AndroidAuto) - sometimes freezes, CAN question
      08-16-2023, 05:51 AM   #1
rgz_ltd
Drives: BMW F11
Question MMI Carbox (Carplay, AndroidAuto) - sometimes freezes, CAN question
Hello,
Sometimes i have problems with my MMI BOX (CIC, 2012 wide screen)
There are 2 types of same (i think) problem, and its about mmi box freezes.
1. I have error on my screen
Code:
CAN question, please check as follow:
1. CAN cable connection
2. Dial switch
3. Carplay box type
Please contact your supplier for detail.
and cant use iDrive controls (its freezed). Sometimes in 2-5minutes everything goes to normal and both MMI menu/normal BMW menu works perfectly, i can switch between those 2.
2. I have normal BMW view, but iDrive also doesnt work and i cant navigate with it. (wheel keys works -i can change radio, 1,2,3... buttons also because i have memo on 1 for car statistics) but i cant use iDrive wheel or buttons. Same like above sometimes it goes away and everything works, sometimes i need to close my car for 5-10min and when start it again its mostly OK then (i think it needs to power off MMI, so theres like 10min idle)
Both looks like problem with MMI and it blocks my iDrive.
Mostly everything works on cold-start. And if i turn off my car for 10-30min (like shopping) and go back then i can get that freeze.
About wiring, PINs, instruction etc. - imo everything is OK because everything works mostly. I got that freeze's randomly, not everytime. But it can be super annoying when im on the road and lost my navigation while refuel or something.
I had found same problems on different topics, but without solution. So i wanted to make dedicated thread for that
      06-17-2024, 05:57 PM   #2
hyri
Drives: e60 525d
Hello, i have same problem but on other chasis, did you please resolved this issue ? thank you.
      11-25-2025, 06:12 AM   #3
BMNYC
Drives: 528i 2011
Hi Guys, I am same issue even worse, it comes on and off and the airbag light. Also when it goes on and off it also affects the ac. Did you guys find a solution or you had to remove it. Please let me know, mechanic and I are looking to see if we can troubleshoot it today if not I need to return it. It’s so frustrating…
