2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications 0x120708 Load pressure control 2, Plausibility: Pressure too low
      02-21-2018, 01:03 PM   #1
Milestune
Hiya,
I have a 2011 550xi with JB4... On a hard acceleration , up a hill I got drivetrain warning. this code came up
120708 0x120708 Load pressure control 2, Plausibility: Pressure too low
I think I also heard the engine pinging too.. (Don't know if this is possible, seeing it has knock sensors...)?
Anyone have any thoughts on this?
      08-12-2018, 04:30 PM   #2
awfulhak
Drives: M5 F10
Hi
Have you found what was the issue?
      04-11-2019, 10:37 PM   #3
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
I currently have the 120308 and 120708 codes
      04-12-2019, 06:23 PM   #4
ziekxq
Drives: 2011 535i xDrive
This is what I got when I checked the code:
Check lines and plug connections between the following components:
- DME.
- Charging pressure sensor.
Replace charging pressure sensor.
Check the air duct between turbocharger and intake plenum.
Check whether wastegate valve is jammed in open position.
On vehicles with pneumatically operated wastegate valve:
- Check wastegate valve pressure converter.
- Check vacuum line and vacuum.
On vehicles with electrically operated wastegate valve:
- Check electrical wastegate valve.
- Carry out system test of electrical wastegate valve.
      04-18-2019, 03:42 PM   #5
warpeacelove
Drives: 550i
120708
Possible fault cause:
- Charging pressure sensor 2 faulty
- Pressure converter wastegate valve 2 faulty
- Wastegate valve 2 faulty (stuck open)
http://bmwfault.codes/XMLDiagView?do...A0ADQANwAwADQA
