2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Is 6WB HUD cluster fit F10 without HUD
      03-25-2018, 07:14 AM   #1
mrmarie
Drives: BMW F10
Hello all,
I have F10 2011 without HUD and need to change the cluster from 6WA to 6WB
There is any problem if i install HUD 6WB cluster? Will get any error because not connect HUD?
Appricate your help
Thank you
      03-25-2018, 09:47 AM   #2
Stück
Stück's Avatar
Drives: F15 X5, E46 330i, R56 Mini.S
No, it works fine with cars equipped either way. It just needs to be coded appropriately.
      03-26-2018, 02:16 PM   #3
mrmarie
Drives: BMW F10
Thank you for reply
Another question please
After coded the cluster the Km will adjust automatically or should adjust it manually to be the same old KM cluster ?
Thank you
      03-26-2018, 02:51 PM   #4
Stück
Stück's Avatar
A virgin cluster will adopt chassis mileage upon programming. A used one will not.
      03-26-2018, 03:28 PM   #5
mrmarie
Drives: BMW F10
Thank you again
The get 6WB virginized cluster, so i think it will adjustment mileage automatically, right!
Do you know any remote coding service?
Appreciate your help
      12-16-2019, 02:49 PM   #6
Gjohnson7
Gjohnson7's Avatar
255
Drives: 11' BMW 535i, 12' Lexus RX350,
2011 535i  [0.00]
Sorry to dig this thread back up, but I am thinking about upgrading to a 6wb cluster and have a few questions.
Are there variants of the 6wb cluster that will fit the f10 or are all of the 6wb clusters the same. In other words, do I need to look for a specific donor car? I have been trying to research the swap and have come across a few G30 6wb clusters that I would love to pick up, but I'm not sure if the G30 cluster will fit. It seems like my current F10 cluster has a "hood" that spans over the top of the cluster that does not seem to be present on the new G30 6wb cluster.
      12-16-2019, 03:25 PM   #7
Qsilver7
Qsilver7's Avatar
Drives: F06 650ix GC / F15 X5 50i
Use one of the online part database sites...you can look up the two 6wa and 6wb clusters...then click on the 11 digit BMW part nbr and it should list all other BMW models that use the same part nbr. That way you'll know what donor BMWs you can use.
The 2nd pic you posted looks like the new style cluster used in the new G chassis BMWs...where just looking at the two outer (smaller) gauges indicates that the cluster isn't compatible with the F chassis. The F10's 6wb cluster has 4 circular gauges that are open on the side...whereas the f10's 6wa cluster has 4 circular gauges that are open on the bottom (almost like a horseshoe).
{6wa cluster}
{6wb cluster}
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
      12-16-2019, 03:47 PM   #8
Gjohnson7
Gjohnson7's Avatar
255
2011 535i  [0.00]
Thanks for the quick post. I will give that a shot.
Checkout my YouTube channel, Like and Subscribe. https://www.youtube.com/user/Gjohnson7771
MHD Flash, RVG Catless DP, RVG CP, RVG Boost Pipe, Walbro 455 LPFP, Style 433 Wheels, BC Coilovers, Ebay Strut bar, M-Sport Front Conversion, RVG FMIC, 6WB Cluster.
      12-16-2019, 04:03 PM   #9
Qsilver7
Qsilver7's Avatar
No problem...using the www.realoem.com website...and using my 2013 f06...I get these possible donor BMWs for the 6wb instrument cluster. And you can also see multiple BMW part nbrs that have been used during the production run of these BMW models.
      12-16-2019, 04:37 PM   #10
Gjohnson7
Gjohnson7's Avatar
255
2011 535i  [0.00]
Awesome. That really helps.
      10-12-2021, 03:42 PM   #11
Napas
Drives: f11 520d m
Hey ,
Is there a way to identify if the Cluster 6WB has capacity to integrate with HUD or not?
      10-19-2021, 06:37 AM   #12
OLIVERSTAN
Drives: BMW F10
No, just needs to be coded appropriately.
      10-19-2021, 06:47 AM   #13
spielnicht
Petrolhead
spielnicht's Avatar
440
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
Yes, it would have an extra plug inlet on the back (light beige if I recall correctly).
Originally Posted by Napas View Post
Hey ,
2024 X3 M40i
2014 550i
2008 Z4 3.0si 6MT
2011 Z4 35si (sold)
Tags
6wb, f10
