2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding BMW F10 Coding DIY (and other Fxx models)
      01-04-2019, 08:07 AM   #375
Kwood-F10-535i
Drives: 2016 535I
Originally Posted by shawnsheridan View Post
Just this as far as I know:
E-Sys - Flashing ECU Guide v.1.0.1.pdf:
https://mega.nz/#!VwIzGJJY!oHCQrh-ax...syn-9eEytBH1qo
Thanks I have seen that one before but the links in it are dead.
"How to identify dependencies:
http://www.bimmerfest.com/forums/showpost.php?p=8688725&postcount=18"
Is the info I need.
      01-04-2019, 01:25 PM   #376
shawnsheridan
shawnsheridan's Avatar
Drives: 2018 Alpina B6 650ix GC
Is the info I need.
https://www.bimmerfest.com/forums/showpost.php?p=8688725&postcount=18
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      01-04-2019, 02:38 PM   #377
Kwood-F10-535i
Drives: 2016 535I
Thanks it appears they only have the Https site up. Never would have thought to check it.
      01-04-2019, 02:50 PM   #378
shawnsheridan
      01-16-2019, 04:36 AM   #379
rychu9191
Drives: bmw f10
Exclamation
Hi,
I need to disable PDC only on reverse gear.
I'm only using button PDC.
Does anyone have instructions to code this?
      01-16-2019, 07:01 AM   #380
shawnsheridan
Originally Posted by rychu9191 View Post
Hi,
PDC => AKTIVIERUNG_RUECKWAERTSROLLEN = nicht_aktiv
      01-16-2019, 08:02 AM   #381
rychu9191
Drives: bmw f10
I changed to nicht_aktiv but no changes.
      01-16-2019, 09:05 AM   #382
shawnsheridan
I have no idea then. It should have worked.
      01-17-2019, 06:20 AM   #383
rychu9191
Drives: bmw f10
can you know how to deactivate the display to run it when I feel like it?
      01-17-2019, 07:08 AM   #384
shawnsheridan
Not possible.
      01-17-2019, 02:35 PM   #385
Yup.... Use the button.
      01-30-2019, 12:59 PM   #386
supraken
Drives: car
As I understand when you want to get a replacement key through the proper channels, it'll be encoded with information tied to your VIN and CAS module, but comfort access will still not work due to our cars only having 2 keys working with comfort access at a time.
Has any one had any success of removing one of these keys from the CAS registry using tools like ESYS ? If so can you share the steps and how to add the new key ?
Trying to get a replacement for a 2nd key that was lost, and dealers are charging $160-170 to do the coding.
      02-19-2019, 08:10 AM   #387
hrnskr
Drives: E90 335i N54
Originally Posted by Protious View Post
Just got my ENET cable today and started coding away.. Hopefully it helps some of you (if you decide to code):
TPMS SENSOR READINGS
HU_NBT / 3001 / RDC_SAFETY -> activ / Werte=01
AUTOMATIC HEADLIGHTS
FRM / 3050 / FLA_AUTO_AKTIV -> automatisch/ Werte=01
FRM / 3050 / FLA_VERBAUT -> aktiv
HU_NBT / 3000 / HIGH_BEAM_ASSISTANT -> aktiv
KAFAS2 / 3050/ FLA_ON_OFF -> aktiv
SIDE MIRROR CLOSING W/ KEYFOB
FRM / 3020 / ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN -> aktiv / Werte=01
CAS / 3003 / KOMFORTSCHLIESSUNG_FB -> activ / Werte=01
CAS / 3003 / KOMFORTSCHLIESSUNG_PA -> activ / Werte=01
SIDE MIRROR DELAY TIME
CAS / 3003 / KMFRT_SCHLIESSEN -> wert_01 / Werte=00 (0F Default)
DRIVER'S DOOR UNLOCK ON START / STOP
CAS / 3002 / ER_KEYOUT_AUTOVR -> activ / Werte=01
ENABLE CLOSE TRUNK FROM KEYFOB / BUTTON
HKFM_LS / 3010 / SCH_FBD -> activ / Werte=01
HKFM_LS / 3010 / SCH_TOEHKI -> activ / Werte=01
HKRM_LS / 3010 / TASTER_FBD -> activ / Werte=01
DISABLE LEGAL DISCLAIMER
HU_NBT / 3001 / LEGAL_DISCLAIMER_TIME -> kein_ld
HU_NBT / 3001 / MACRO_CAM_LEGALDISCLAIMER -> kein_ld
DISABLE PROTECTION FOR WINDOW OPENING / CLOSING (FRONT / REAR)
FRM / 3030 / FH_TUER_AUF_STOP_MAUT -> nicht_aktiv / Werte=00
JBBF / 3070 / FH_TUER_AUF_STOP_MAUT -> nicht_aktiv
DVD IN MOTION
HU_CIC / 3000 / SPEEDLOCK_X_KMH_MAX -> FF
HU_CIC / 3000 / SPEEDLOCK_X_KMH_MIN -> FF
HU_CIC / 3000 / VIDEO_HANDBRAKE-> Nicht_activ
HUD TURN SIGNALS
KOMBI / 3008 / HUD_PIA_BLINKER -> aktiv
KOMBI / 3008 / BLINKER_HUD_ENABLE -> aktiv
HU_NBT / 3000 / HUD_TURNSIGNAL -> aktiv
NAVI TRIP IMPORT
HU_NBT / 3000 / NAVI_TRIP_IMPORT -> aktiv
ENABLE ADDITIONAL CODEC SUPPORT
HU_NBT / 3000 / ENT_CODEC_OGG --> aktiv
HU_NBT / 3000 / ENT_CODEC_XVID --> aktiv
HU_NBT / 3000 / ENT_CODEC_VDC --> aktiv
DISABLE ACTIVE SOUND DESIGN
ASD / 3000 / Baureihe -> F021
ADD GPS CURRENT POSITION MENU ITEM (UNDER OPTIONS)
HU_NBT / 3000 / NAVI_POSITION_MENU -> aktiv
Hi
I just bought my cable and downloaded the esys but need help how to code it.
      02-28-2019, 02:35 PM   #388
samaberman
Drives: f10 535 Msport nos b20v civic
f10 2013+ cheat sheet
hey guys,
im looking for f10 2013 cheat sheet for esys codeing
thanks in advance,
Sam
      02-28-2019, 03:17 PM   #389
shawnsheridan
Originally Posted by samaberman View Post
hey guys,
thanks in advance,
Sam
You cannot Send or Receive PM's yet. Send me one when you can.
      03-10-2019, 04:15 AM   #390
mannerboy
Drives: F30 to F80
Hello enjoyable forums
1-I want to always have the leds in the mirror for the F10 520i 2014
2-Tail lights I want to use the brake light as a turn signal
      03-19-2019, 09:31 PM   #391
teja535d
Drives: BMW 535d M-Sport (F10)
Hey guys, new BMW owner here... picked up a 2015 535d M Sport. Wondering if anyone was able to have the fogs on w/ DRL? I was able to get it working with the welcome lights but haven't found it w/ the DRL's. I'm using bimmercode.
Thx.
      03-31-2019, 12:09 PM   #392
filius27
Hi,
search for my vehicle BMW F10 2012 NTB 535d software E-sys, ESysLauncher and PSdZData.
Thank you in advance!
      03-31-2019, 01:14 PM   #393
shawnsheridan
Originally Posted by filius27 View Post
Hi,
PM sent.
      04-13-2019, 11:01 AM   #394
Jjtitus
Drives: 2015 535i
Help! I was coding active high beams and the coding stopped halfway and now the head unit doesn't turn on. Have no clue why it did this as I've coded other options before this with no problem. Did I just screw something up??
      04-13-2019, 11:23 AM   #395
Jjtitus
Drives: 2015 535i
Crisis averted. The first time I tried to restore it didn't let me. Did it again and all works now.
      04-16-2019, 02:34 PM   #396
pmunks
Drives: 2015 528i (f10)
just picked up a 2015 f10. need to get my coding skills on point. d/l bunch of s/w and MOPS. and got my cable ready for E-sys. guess need i need a a copy of launcher still trying to absorb all this new info... so it begins
