11-05-2018, 09:26 PM | #23 |
Rep 361
Watching this thread diligently because although the last mechanic that looked at my N63 couldn't find any issues and the car is running fine now, as soon as it gets to 3/4 of a tank it starts misfiring which leads me to believe HPFP.
I've got a Foxwell Scanner that logs freeze frame data and it hasn't given a fuel pump code, it did give a "low fuel pressure" code along with a DTM. Running fine atm but I've had to have it towed several times before...blah.
Janet Jackson Unbreakable World Tour
11-06-2018, 10:13 AM | #25 | |
Rep 659
I had low pressure code/DTM as well on bank 2 and replaced the pump. All is good |
Kyngofpop676.00 |
11-23-2018, 06:32 AM | #28 |
krrrraaauuuuut
177
Rep 524
I recently had much drama with DTM and thinking it was coils and such, so a few tows and several hundreds (even though I had aftermarket warranty), it was the HPFP and all has been well for a few months.
I am however smelling at times some fuel, to which I thought was running a little rich. Can something leak from the pump replacement from the dealer?
(Current) G12 750i X Drive / M-Sport / LOADED
(Current) 997 Turbo / 6MT / HRE FF01, Land Rover LR3 - Overlanding Family Adventure Shed, E60 525i - "family beater", Alfa Romeo Spyder Veloce - garage art (Gone) F10 550i / M-Sport, D2 Audi S8, AP1 S2000, Z32 300zx, S13 240sx |
11-30-2018, 05:48 PM | #29 |
Rep 361
Changed a few coils and plugs and went with Liqui-Moly oil and the misfires have subsided for now. Not sure if this will cure my issue but the car sure is quiet for now.
Relevance: seeing if any of this leads back to the HPFP. Just crank it up in the cold and no DTM. Will report back later.
12-05-2018, 05:16 PM | #31 |
Rep 74
Drives: BMW 550i GT Xdrive
I had a recall on the fuel pump on a 2011 550i plus Aux turbo coolers under the recall.
01-17-2019, 08:30 PM | #32 | |
Rep 40
01-17-2019, 08:45 PM | #33 | ||
Rep 361
01-17-2019, 08:59 PM | #34 |
Rep 40
I bought bosch one from fcp $250, it looks like people used it with no issues. I saw some on ebay for $80 (the sellers stated original BMW) but they were old stack with 2011-2013 production date ( so i passed on ebay items) . The one i got from fcp is 2018, and fcp have lifetime replacement which i used couple times for my audi. Where did you get yours?
Kyngofpop676.00 |
01-17-2019, 09:15 PM | #35 | |
Rep 40
01-18-2019, 09:16 PM | #36 | ||
Rep 361
04-05-2019, 11:14 AM | #37 |
Rep 8
2011 BMW 535i. I as well have the P0171 code with several cylinder misfires. On a cold start my car sounds smooth. But when the engine has warmed up and I start the engine there is a extremely loud and high pitch noise that shows up. It rough idles with the rpm going up and down around 1000rpm. Feels like the car is reving itself. But when I rev the engine up to 3000 rpm the sound goes away and it idles smoothly. Anyone have any ideas?
04-17-2019, 11:24 AM | #38 | |
Rep 262
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
04-23-2019, 10:32 PM | #39 |
Rep 2
So im gonna share my experience, First time i had a pull to about 130 threw a DTM light, next day everything fine, forward 2 weeks later another hard launch threw a DTM light, managed to get back home with no issues, next day i started the car with rough idle, plugged into the OBD got a misfire on 5 and 6 with low fuel pressure code. So i checked the engine and saw that a seal surrounding the 5 and 6 spark plugs was leaking a little bit of oil. I bought the new head cover seal and replaced it, cleaned up all the oil and replaced all the spark plugs. Started the car with no luck, shaking and rough idle, this time 5 , 6 , 8, so i suspected that it could possible be the HPFP on bank 2, switched it sides and got misfires on 1 and 3, so after 2 weeks of scratching my brain was able to eliminate the problem.
As of now waiting on a new HPHP and hopefully that will be my source of problems, ill keep you guys updated Seems like it was a coincidence that the leak was where the initial misfires occurred or not, still kind of confused Bought the car 1 month ago, so I am very pissed off that i had to go trough this right away Last edited by PLSTwinTF06; 04-23-2019 at 10:38 PM.. |
04-29-2019, 07:06 PM | #40 |
Rep 2
So I got the new HPFP, well a used one from a 14' M6 apparently that's the part number on my pump. all is well now, seems to be, but now im driving a bit paranoid, any sort of shaking just make me think that the other pump might be soon to follow
For those wondering I was getting Codes P0087, P15DF, P0300. as well as 3 misfire codes, but by switching the pump back and forth, was able to determine which one it was, good luck out there ! Last edited by PLSTwinTF06; 04-29-2019 at 07:13 PM.. |
Kyngofpop676.00 |
04-29-2019, 08:08 PM | #41 | |
Rep 262
I probably look like a crackhead when I pull over or pull into a parking lot and I'm frantically running around placing my ear to parts of my car and crawling under the car then leaning under the hood, then my wife says "hey idiot we just need gas", haha. The DTM ruins you for life. I have night terrors of just that dreaded BMW chime and the DTM screen attacking me and my car. Glad you got it all fixed up.
2011 550i (N63)
Kyngofpop676.00 |
