2010 2011 BMW 5 Series Forum F10 BIMMERPOST Universal Forums Off-Topic Discussions Board Health, Fitness, Martial Arts, and Nutrition Gym Talk! Daily gym related talk
      09-24-2021, 07:43 PM   #2905
JP10
JP10's Avatar
1518
Drives: M3
Originally Posted by floridaorange View Post
Stopped most supplements and trying to gain muscle the old fashioned way this time around. And so far I feel alot better, just generally speaking. The weights do feel a little heavier, no question about it, but I feel good n strong. Ordered some dip bars so I can do them at home more. Good times.
Supplements aren't needed. Health industry is full of false advertising. I'm a protein only kind of guy, and the only reason is because it's an easy meal replacement.
The stuff that works requires a prescription or it's illegal, that's about all there is to it.
Glad to see you're back after it! I slowed down myself with the wedding and everything that came following. Have been able to get in the gym about 3-4 times a week, but I was a 6-7 days a week guy for what felt like years. Trying to get back to 5x a week currently.
      09-25-2021, 12:26 PM   #2906
Oldgixxer
Oldgixxer's Avatar
221
Drives: nothing fast
TRT is a helluva thing!
-'22 X3MC,G22 430i vert
-'09 Busa,'05 GSXR-1K(GT28R turbo)'00 Busa(GT3582)
Gone but not forgotten:
-'20 M550i,'18 X2,F30 328xi,'07 E63 AMG (1st W211 63 in the 11s),997 C4S Cab,CLS55 AMG,E55 AMG,C55AMG
      09-25-2021, 01:54 PM   #2907
floridaorange
floridaorange's Avatar
Drives: 2013 bmw 320i xdrive
well everyone truly is different my dude — creatine turns me into some kind of manimal… jokes aside - my lifts are heavier and endurance higher and unfortunately i get more temper and short on patience - i know it's joked about on bodybuilding forums - but that stuff is no joke when i take it. I retain and consume a TON of water even off 5 mg's of creatine. No longer serves me to be a gym bro though - which is sad cuz i make a great gym bro :
Stage 2 BM3
Originally Posted by GrussGott View Post
Sounds pizzagatey.
JP101518.00
      09-27-2021, 09:32 AM   #2908
heitzke
heitzke's Avatar
240
Drives: '15 M4 base, '91 Miata
Well, meet didn't go as expected but finished 5/9 lifts and totaled a 1325.1 at 194lbs. Not my best performance but so it goes.
They REALLY messed us up on squats and used a 55lb bar and went back and adjusted weights up AFTER. That made my opener a 467, and then my second a 495. I had a 485 in my, which was the attempt I selected, but failed a 495 twice, sticking about midway through the lift.
Deadlift was fuckin moving, ripped a 530 open, then 551 moved like nothing so I jumped to 572 and got stuck at lockout. Need to work on some hip drive movements and i'll definitely pull a 600 this year.
Finished with:
467 squat
308 bench
551 deadlift
I DID win the 90kg open class though, so there's that. Not bad for being 35 and should be competing in sub-masters.
Pure 2+ M4 | NA Miata
Oldgixxer221.00
JP101518.00
F32Fleet2632.50
      09-27-2021, 09:34 AM   #2909
Oldgixxer
Oldgixxer's Avatar
221
Excellent numbers!!!!! Congrats
heitzke240.00
      09-27-2021, 09:49 AM   #2910
heitzke
heitzke's Avatar
240
Thanks! Onward and upward I guess. Next meet prep will go a little better and hopefully be healthier to break some TN sub-masters records.
The USPA squat record for my class is fairly light and should have had it this meet considering i've smoked 500's in the gym many times.
      09-27-2021, 01:14 PM   #2911
JP10
JP10's Avatar
1518
Drives: M3
Oh for sure, I would hold a ton of water on creatine - too much in my opinion hence why i don't take it hahaha. I used it in the past a ton, to the point where I think my body got use to it. Then I got off for about 2 years. I wanted to try using it again maybe a few months ago and I went up 10lbs in a week then kicked it because I was a balloon lmao. I'm just at the point where I'd rather be lean then huge. Unfortunately this is work driven to an extent - work attire and suites.
      09-27-2021, 01:18 PM   #2912
JP10
JP10's Avatar
1518
Drives: M3
That it is, especially if you have the right doc lol!
I've done a ton of research, once I am through having kids I plan to run it if my lifting passion still persists - were talking like 10-15yrs in the future. Testosterone panels should be required for males once you get into your 40s, having low T is not a good thing and getting those numbers back into proper range (or well above for us deviants) should be talked about more - just my opinion. Why be tired and start to development moobs when there is a relatively low risk (at low doses) fix to the issue.
      09-27-2021, 01:26 PM   #2913
SpartanGA
SpartanGA's Avatar
Drives: 2018 BMW M4 Comp F83
I've done a ton of research, once I am through having kids I plan to run it if my lifting passion still persists - were talking like 10-15yrs in the future. Testosterone panels should be required for males once you get into your 40s, having low T is not a good thing and getting those numbers back into proper range (or well above for us deviants) should be talked about more - just my opinion. Why be tired and start to develop moobs when there is a relatively low risk (at low doses) fix to the issue.
Lifting or not, TRT is an excellent idea. I was close to the minimum of 300 and now hover in the 800-900 range. I don't get the anger issues (I think this is more indicative of your personality with or without the T) Hormone balance is crucial as you age. You will continue to look younger and keep a higher metabolism plus gym is easier.
Maybe a DECA prescription could help too.
      09-27-2021, 03:40 PM   #2914
floridaorange
Finished with:
467 squat
308 bench
551 deadlift
Finished with:
467 squat
308 bench
551 deadlift
May I ask your height? Nice work - very solid!
Stage 2 BM3
Sounds pizzagatey.
      09-27-2021, 05:00 PM   #2915
heitzke
heitzke's Avatar
240
Yeah totally, i'm 5'8". Long arms are a huge hindrance on bench but work well for a deadlift
      09-28-2021, 09:42 AM   #2916
heitzke
heitzke's Avatar
240
Also hard agree here. I've been on TRT for ~7yrs now and it really changed things for me. When I went to get my levels checked mine was like... 90 (seriously) and I was 28. I was tired all the time, gym was a grind for a inch of progress.
I split a test e dose 2x a week and it's been much better since. Giving myself shots forever isn't my favorite activity, but it's better than the alternative for me.
      10-04-2021, 12:17 PM   #2917
UncleWede
UncleWede's Avatar
I went on a 7-day cruise to Alaska, and they had a gym on board. I haven't been inside one since last November?
Anyways, I started doing 2-a-days, actually pulled it off 3 of 7. Now I'm back home and gots da itch BAD. I gotta put aside my hatred of DRIVING to a gym, and get back into one, somewhere.
      10-09-2021, 09:20 AM   #2918
floridaorange
Been adding more cardio and feeling overall stronger as a result - had been neglecting my runner self for too long. Now the goal is to not overdo it.
Stage 2 BM3
Sounds pizzagatey.
      10-09-2021, 10:25 AM   #2919
Oldgixxer
Oldgixxer's Avatar
221
Good for you! What type of cardio and frequency? I've been lazy lately and have been neglecting the cardio
      10-09-2021, 03:34 PM   #2920
floridaorange
For the past couple yrs most my cardio has been HIIT and running in place between different exercises at home ... like high knees running in place.
I thought running was going to make me lose too much weight, and it might eventually if I overdo it. Since then I've added more calories to my diet and now I think I'm at a good balancing point for being able to run without loosing the hard earned muscle.
Anyway, lately I have been running to the park, about a mile then at the park doing some pullups, dips, and body weight rows using the parallel bars. Then running home. So 2 miles, 3 days a week. Nothing crazy or exhausting. I feel overall healthier, more energy, more alert, less drowsy during day, etc. I bought a good running shoe and that has helped motivate me as well.
I should also mention I use an airdyne stationary bike when I want to switch it up. Alternating cycling & running is more fun than I anticipated.
Stage 2 BM3
Sounds pizzagatey.
Oldgixxer221.00
      10-22-2021, 04:48 PM   #2921
AustinZ4
Drives: 2007 Z4 3.0i SMG
2007 BMW Z4  [0.00]
Over 40 here. Have been on TRT for over a year now. Woah, what a difference. Been in the gym pretty regularly for 5 years before that. My T panels put me at low 3's. Doc got me to high 9's. Even outside of the gym, life is better.
Oldgixxer221.00
      10-25-2021, 09:29 AM   #2922
JP10
JP10's Avatar
1518
Drives: M3
I had a rough 3 weeks with being extremely busy at work, and nothing has changed in that regard, but finally got back in the gym this morning. 40mins lifting shoulders and biceps following by a 4+ mile jog. Felt good getting back in there. I wasn't gaining weight or anything being out of the gym, actually the contrary because I was drinking more than I should have been. Trying to get my health back to the priority it has been over the last 7+ years - as some on here are aware, I use to be a 6-7 days a week in the gym.
I also have a good friends wedding to go to next weekend, so that gives me a little goal to work towards as well. Hopefully I can keep things on track the remainder of the week!
      10-25-2021, 10:31 AM   #2923
ramman434
Drives: '16 F10 535i M-Sport
I've gotten tired of irregular gym routines that have been going on since the summer. I usually go after work, but have had dinners/events getting in the way in the evenings and my avg gym time has been 1-3 days week, and usually on the lower end.
Decided to get up at 5:30 today to get an early workout. Was in at 5 til 6am and man was it packed! It was as bad as when I get there in the afternoon, but by the time I left a little after 7, it was almost dead.
It was international chest day, so got about 5 exercises in, but kept it a bit lighter as my body isn't used to working this early on no fuel. Then did 10 min of interval speed sprints on the treadmill & another 12 min of elliptical.
I've got a personal goal to get below 200lb. so I can have a beer. Usually I fluctuate 10lb. throughout a week, but haven't been in the gym regularly for that to happen. Therefore, haven't had that delicious calorie intake in 3 weeks...so aiming to get it done this week, since I'm gonna be on a boat Sat.
'98 Cobalt Green Pearl Nissan 240sx SE -manual swap, Fortune Auto Coilovers, Blitz Nur Spec R catback, CF hood w/flush mounted pins SOLD
'07 Montego Blue E92 BMW 335i - 6spd. Weiss Licht Angel Eyes, AFE DCI, Vishnu 3.5 - SOLD
'16 Carbon Black Metallic F10 BMW 535i M-Sport - eBay Special Strut Bar, CF M4 Mirror caps: TOTALED 11/21/21
      10-27-2021, 04:59 PM   #2924
floridaorange
Every 5-10 posts I'll see someone praise TRT. Surely there must be a downside or no?
Stage 2 BM3
Sounds pizzagatey.
      10-27-2021, 09:00 PM   #2925
JP10
JP10's Avatar
1518
Drives: M3
As long as it's controlled properly then there isn't many besides you naturally will stop producing testosterone. Hence if you want to have more kids naturally it isn't the best decision. You can properly get off, and restart your production, but there is always risk that the affects could be long lasting. With everything in life, moderation is key. I've done way too much research on this shit in my younger days, finally concluded that it wasn't a good decision as I want kids.
Once I get through that phase I plan to at least understand where my T levels are. If they're low and my goals are met then I would definitely pursue it. I think more middle aged men should get panels done to understand what could be wrong for sure.
      10-28-2021, 09:51 PM   #2926
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Claim: You should be able to lift your body weight when performing a squat, deadlift, and power clean before you think about using a lifting belt.
Thoughts?
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
Copyright ©2000 - 2021, vBulletin Solutions Inc.
