2010 2011 BMW 5 Series Forum F10 Side mirrors not folding when locked |
01-10-2021, 11:39 AM | #1 |
Rep 11
I have a 2016 f10 and when in BimmerCodes I’ve activated both the folding mirror options (2 of 2) but still can’t get my mirrors to fold when locked. What am I doing wrong?
01-10-2021, 12:33 PM | #2 |
Cole
321
Rep 498
OnlyGerman363.50 |
01-10-2021, 12:39 PM | #3 |
Rep 143
I have the same car like yours and that was the FIRST thing I ever coded. It has worked from day one. I initially used Bimmercode as you did (I now mainly use Carly for the built-in codes because it's faster, and Bimmercode for expert mode stuff).
Something I did notice on our cars with this code set to fold, is that when locking with the remote, I have to hold the lock button half a second longer than just a quick press (and I do mean half a second, don't need to really "hold it", per se), otherwise the mirrors sometimes don't fold. I don't know if that could be what you're experiencing. Otherwise, I would revert your coding via Bimmercode backup, let the car systems go to sleep, and retry the coding. It really should be one of the easiest and most consistently working coding options out there for our cars, I'm sorry you're having trouble. |
01-10-2021, 12:40 PM | #4 |
Rep 11
I feel dumb thanks that worked
OnlyGerman363.50 |
01-10-2021, 11:00 PM | #6 |
Rep 5,365
You can also code the duration; I coded no delay. It's a wert change, but I don't remember the value.
OnlyGerman363.50 |
01-11-2021, 04:58 PM | #8 |
Rep 5,365
02-21-2021, 01:52 AM | #9 |
Rep 1
Hi guys, I know this is old topic but have now f10 and also using bimmercode with vgate. I did not have any issues with changing back light or demo etc but with the mirrors I want them to close after one click on fob not holding the button is it possible? I have both options active and have change the were for 00 but anyway you have to hold Botton for a two sec.... Please help as I am newbie in this
02-21-2021, 01:38 PM | #10 | |
Rep 5,365
02-21-2021, 07:15 PM | #11 |
Rep 143
They go through the wert values that you guys were looking for in the following thread. I will be trying this later today.
Someone on the thread did mention that setting it to zero (ie, no delay) made their windows not close at all. So we may have to play with it a bit to get it to work. Make sure to revert to a good backup each time something doesn't behave the way it's supposed to, and then start again from that point...imo anyway. https://f10.m5post.com/forums/showthread.php?t=1532474 For the lazy amongst us: Code:
NO DELAY: CAS->3003 FH MASTER->KMFRT_SCHLIESSEN->Werte=00 1/4 Second Delay: CAS->3003 FH MASTER->KMFRT_SCHLIESSEN->Werte=02 Last edited by EvntHrzn; 02-21-2021 at 08:09 PM.. |
02-22-2021, 12:13 AM | #12 |
Rep 2,591
IIRC there's a downside to zero delay, but I forgot the specifics. I have mine set to 1 second.
2015 BMW 535xi
02-22-2021, 04:02 AM | #13 | |
Rep 143
On the other hand, I do know of a downside to setting the SUNROOF to zero delay. For example, when you want to close all the windows but leave the sunroof vented (if it was already when you left the car,) you wouldn't want it to be on the same timing as the windows (I have mine on a 3 second delay). Or vice versa: when you want to vent the windows, but may not want to vent the sunroof, the delay is good there too. But for mirrors, I can't think of a scenario like that where I wouldn't want them to close or open immediately with lock/unlock. |
02-24-2021, 10:51 AM | #14 | |
Rep 2,591
2015 BMW 535xi
02-24-2021, 01:30 PM | #15 | |
Rep 143
So perhaps I was spoiled by that experience and didn't know that people have experienced problems with setting custom timings for those things, I don't know. |
02-26-2021, 07:00 PM | #16 | |
Rep 2,591
I was hoping you could completely decouple the front windows as well, but oh well.
2015 BMW 535xi
06-27-2023, 06:14 AM | #17 |
Rep 1
Mirror not folding or unfolding automatically !
I recently bought a BMW 530e M sport 2018 model.
Both mirrors are not folding or unfolding automatically though i tried options within the infotynment system and using the key. Any idea why i don't have an automatic mirror folding option !!! |
07-02-2023, 09:36 AM | #18 |
Rep 251
You gonna have to code it in with Bimmercode or icarly or something.
07-05-2023, 09:15 PM | #19 | |
Rep 19
It's annoying that mine slowly closes itself when I lock the car! |
