2010 2011 BMW 5 Series Forum F10 Can you code TPMS Rdc with BimmerCode |
07-02-2023, 06:27 PM | #1 |
Rep 71
My Rdc unit failed (2011 550i MSport) and I replaced it (under the rear bumper). That obviously didn't do it because the Rdc needs to be recoded. Then I used BimmerCode, recoded the CAS module (in novice mode by changing one of the parameters) and that somehow established the connection to the new unit and I got pressure/temp info. However, that seems to be temporary. If I turn off the ignition, I get the TMP error again and if I check with BimmerLink, I see the error "RDC unit/module not coded" or something very close (didn't write it down). I can repeat this process to make it connect but connection is lost once the ignition is turned off.
Does anyone know if I can code the new Rdc unit with BimmerCode? I tried to find documentation on the BimmerCode website but could not. Thanks in advance.
88 S14 M3 (NASA GTS3 racecar) / 11 6MT 550i M Sport / 14 6MT M5 Competition / 15 X5 50i M Sport (tow vehicle)
07-03-2023, 08:24 AM | #2 |
Rep 2,591
No. Need Esys.
2015 BMW 535xi
07-14-2023, 02:42 PM | #4 |
Rep 71
Confirming that Bimmergeeks ProTool coding software was able to do this (I just did it). I am not in any affiliated with them. Just letting people know so that they don't pay the dealer $1000 for this repair (I heard that's what people get quoted).
https://www.bimmergeeks.net/ You do need to buy their bluetooth adapter though. Their software doesn't interface with other bluetooth adapters as far as I can tell. Their coding license is $79.99 and adapter $49.99. Plus, the part which was $286 with shipping. So $416 total. Easy DIY.
