2010 2011 BMW 5 Series Forum F10 Preventative maintenance items at 90-100K miles |
11-06-2019, 04:41 PM | #1 |
Rep 123
Here is a list of things to do yourself if for have a BMW 535i F10 or similar model in the 90-100K mileage range. I bought mine at 60K, now at 100K, planning to get another 100K out of her. Could be very cost effective to buy one at 90K or so, as the average price reflects getting this done for thousands more.
Intake manifold seals Starter Oil Filter Housing Gaskets intake valve clean Starter Parts around $350, 4 hours labor? Water pump, Coolant change, Thermostat, Drive belt, Idler and tension pulleys, tensioner pin, Parts around $575, 5 hours labor Valve cover, Spark plugs, thin socket Air Tube assembly Tube seal Parts around $600, 6 hours labor Front Shock bellows Outer drive shaft Boots, clamp pliers Parts around $100, 5 hours labor Transmission fluid change Transmission Pan Rear differential fluid Part around $300, 3 hours labor Power Stop (drilled/slotted) or OE (stock) Kit Pads, Disc, hardware, sensor Brake fluid flush Caliper Paint (optional) Part around $520, 4 hours labor Best place for parts is https://www.FCPeuro.com for BMW and OE manufacturer parts, parts above based on OE parts (manufacturer for BMW parts). Most parts at FCP include hardware needed to be replaced. Great site for maintenance manuals is https://www.newtis.info/ and part diagrams by Vin # check www.realoem dot com. With these three site you can do almost anything on your car. Check FCPeuro for DIY videos, there are some short cuts on labor verses BMW shop procedures. |
11-06-2019, 04:55 PM | #2 | |
Rep 590
11-06-2019, 06:47 PM | #3 |
Rep 123
These are preventative, or things to do if you have it apart in the group. I have the starter group left to do, at 103K and the auto starts, I want to do it, don't want to tow it if it fail away from home.
11-07-2019, 04:39 PM | #5 |
Rep 123
Yes, coolant and brake fluid should be done at the correct intervals, For brakes, when you push your calibers back all the way, you can get the most effective flush, and coolant since you drained the system anyway. Just reset the interval. These are group things to do, just makes sense to do things while they are accessible.
If you need to do any of these again, FPCEuro credits the cost on return of the old. |
11-08-2019, 08:06 AM | #6 | |
Rep 2,590
11-10-2019, 02:14 PM | #7 |
Rep 123
I don,t do the oil, they are great and I would feel guilty, but all the high cost items I will. I think redoing a 100K car this way is very cost effective, never pay twice for a part. Wish I went with the stock brakes, Powerstop are great brakes, but I my second set won't be free.
01-11-2020, 12:59 PM | #8 |
Fueled by Recycled Dinosaurs!
630
Rep 1,171
Drives: F06 M6
In regards to the valve cleaning. Did you use a spray product like CRC GDI IVD?
2015 F06 M6 Silverstone Metallic II, Individual Full Leather, B&O, Night Vis, CCB, RKAutowerks (CP Rods/Pistons, DI Cams, CF Intakes, Coated DP's & Billet Diff Brace), InfinityAuto Turbo Inlets, Mishi Oil Cooler, JB4, XHP S3, BM S3
01-16-2020, 03:43 PM | #9 |
Rep 123
I haven't done the intake/starter yet. I believe the N55 fixed the valve coking issue the N54 had with the better PVC system. But will walnut blast if it is needed. Have you heard the CRC works?
01-18-2020, 06:34 PM | #10 |
Rep 9
Nice write up! Mine is at 108k and I have to replace the oil pan. Not sure if the oil pan is bad or the gasket is bad but there was about 1qt of oil on the floor today sadly and based on the research (2 TY vids) it’s a real pain in the butt to get that puppy out! I’m new here and waiting to be allowed to post, I’m hoping someone can give me a little help with that.
01-22-2020, 11:00 AM | #11 | |
Rep 452
xander_g989.50 |
01-22-2020, 11:02 AM | #12 |
Rep 452
Starters are known to go on these cars. Same starter used in e90 and other models. Pretty straight forward to do. I did mine a few months ago. Good thing for me it died in the driveway. So no need for a tow.
01-22-2020, 01:11 PM | #13 |
Rep 1,124
Drives: G30 M550i
I had my front axles replaced recently which apparently are pretty common item on these cars, and I have around 55,000 miles on the odometer
