2010 2011 BMW 5 Series Forum F10 BIMMERPOST Universal Forums Cosmetic Care & Detailing (PPF/Wash/Wax/Detailing/Restoration/Repairs) Clay Towel and Wax
      11-02-2023, 04:46 PM   #1
ZCPMV8
Drives: BMW M3
Clay Towel and Wax
Anyone have experience with a clay towel or mitt? I know it's usually recommended to polish after using real clay... however, since these towels aren't supposed to marr the paint, is it ok to skip the polishing and jump straight to waxing?
I'm planning on trying this using the gyeon lube spray, but heard you can literally just use shampoo.
Any general experiences or recommendations you'd like to share?
Thanks!
      11-02-2023, 04:59 PM   #2
allinon72
allinon72's Avatar
Drives: 20' M2C, 23' X1
It depends how bad the contamination is and how perfect you want the paint. Light/mild contamination isn't going to mar the paint enough to require a polishing step. But if it's heavily contaminated, you'll want to polish regardless of marring because the paint is likely in bad shape either way.
I've clayed many many cars without polishing and they came out fine.
ZCPMV842.00
chris7197535.00
      11-02-2023, 05:08 PM   #3
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
Drives: 11' 335is DCT
Yeah it's fine, polishing doesn't matter for LSP (Although there are some exceptions like special polishes made for ceramic priming) but yeah. Polishing is for how you want the paint to look.
And like mentioned above, I've also clayed before without enough marring for me to warrant a polish.
ZCPMV842.00
      11-02-2023, 06:01 PM   #4
TboneS54
YNWA
TboneS54's Avatar
Drives: 2004 M3 6spd & 2011 M3 DCT
Like other situations, use plenty of lube.
For what's it's worth, I would never NOT polish a car after mechanical abrasion like clay bar/mitt/towel.
If you didn't marr the paint too much, then you probably didn't even need to clay anyway. An iron remover and strong wash would have sufficed imo.
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54
ZCPMV842.00
      11-02-2023, 09:13 PM   #5
ZCPMV8
Drives: BMW M3
Thanks guys. I prob dont need to clay since the detailer told me I don't need it.. but a couple spots especially above the rear quarter panels (M2C) doesn't feel 100% smooth like glass. Overall the paint looks great, just trying to get it as close to perfect as possible.
      11-03-2023, 12:06 PM   #6
TboneS54
YNWA
TboneS54's Avatar
If it were true that you want it as perfect as possible, you'd polish it.
chris7197535.00
ZCPMV842.00
      11-03-2023, 01:19 PM   #7
chris719
Drives: '08 M Roadster
You can use the DIY Detail clay towel or The Rag Company towel without polishing if you are careful. If the surface is extremely contaminated and feels rough these might be too gentle though. Nothing works like a real clay bar. If it's lower panels you can weigh if you really care if there's minor marring.
ZCPMV842.00
      11-03-2023, 01:31 PM   #8
ZCPMV8
Drives: BMW M3
💯 Agree. But want to learn from someone properly before just buying and trying on my own. I may just use my suv as a test subject.
      11-03-2023, 01:36 PM   #9
ZCPMV8
Drives: BMW M3
It's not like really bad or anything. But I still do feel slight roughness in a couple small spots. It's not even an entire panel, it's probably a few inches worth across and a couple inches vertically. That's why I was asking if it's ok to temporarily do the clay towel and wax for now. Until I get myself into and learn how to polish.
      11-03-2023, 02:01 PM   #10
chris719
You don't ever have to polish if you are good with how the paint looks. I would honestly never bother polishing those spots unless it's really bad. Polishing is always removing clear so I like to avoid it if possible, especially on high wear areas.
ZCPMV842.00
shimmy232417.00
      11-03-2023, 02:11 PM   #11
ZCPMV8
Drives: BMW M3
Thanks for all your advice! Maybe I'll wait a bit and just do everything all together a-z when it's really needed.
chris7197535.00
