2010 2011 BMW 5 Series Forum F10 Will it fit? Yet, another post! |
01-06-2015, 07:56 AM | #1 |
Rep 33
Dear all,
I have been following this website for a while as a guest, but I finally decided to create an account! So there goes my first post Here is, yet, another “will it fit?” thread! I was thinking of getting a set of snow tires for the F10 535i Xdrive. I found an excellent set online but they are off a 2005 7series E65. They are BMW OEM BBS Style 94, and they have 8Jx18EH2 written inside them. Google told me they are ET 24. Here is a link to the rims (courtesy of Google again). http://www.bmwstylewheels.com/bmw/94 The guy has 235/50R18 tires mounted on them. And I will be buying it with the tires already mounted. My F10 has sports package. 1. Will the RIMS fit the F10? 2. Will the SET (with those tire measurements) will the F10? 3. If I do end up getting the set, what tire pressures do you recommend? Thanks! Last edited by speedometer; 01-06-2015 at 03:51 PM.. Reason: wrong tire size! |
01-06-2015, 10:51 AM | #2 |
Rep 29,202
I don't see a reason for the rims not to fit.
The OEM 18" for the F10 are 18x8 ET30, so these, with ET24, will stick out 6mm more than OEM F10 wheels. And that's not a problem. But the tires are pretty big. OEM F10 18" size is 245/45/18, so the 235/55/18 tires has a 5.61% larger diameter, and that's a too much I say.
01-06-2015, 01:16 PM | #4 |
Rep 29,202
I don't know if they might rub when turning in the front, and if it's a problem since you've got xdrive.
01-06-2015, 02:48 PM | #5 |
Rep 413
The size of tires 235/55/18 means the diameter is 1.5" bigger than the large 20" and 21" summer wheels of the F10 forum members. I understand you want to save money because the offered wheel set is at a very attractive price. However these wheels are too big but too narrow, and probably used. Think about the several seasons that you will entrust your drive safety to these wheels from a different car.
I would recommend you not to look at the cheapest, but find some cash for a good winter tires. Considering major impact on car control and winter drive safety, this investment worth it. |
01-06-2015, 04:08 PM | #7 |
Rep 29,202
Yes, it's makes a difference, meaning that now they're only 2.14% bigger than OEM size, and shouldn't be a problem.
01-07-2015, 05:09 PM | #8 |
Rep 697
Drives: 2013 535xi
I'm running 245/50/18s on my 535xi with excellent results. OP - your proposed tire size is not an issue.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
01-07-2015, 06:17 PM | #9 |
Rep 33
Dear remmib & cdmulders,
Thanks for your replies. This is all good news. Especially hearing someone using 245/50/18 with no problem What tire pressure do you recommend? I was thinking 36 front, 38 rear. Thoughts? |
01-08-2015, 06:50 PM | #10 | |
Rep 697
Drives: 2013 535xi
Cheers.
01-19-2015, 11:05 PM | #11 |
Rep 235
Cdmulders, nice to see another Ottawa member here. I also have a 535xi M sport package.
Sorry OP if I thread jack ur post.. Hope u don't mind if I ask a wheel fitment question here as well: Will 20x11 +46 with 295/30/20 fits a X drive car no problem? |
03-31-2021, 09:41 AM | #13 |
Rep 4
Hello mate im about to buy 235/50/18 wheels because i want better comfort i saw you write about that size did you buy the wheels how are they is there any problems vibration or rubbing when the car is loaded with 5 peoples. I have f10 525d 2010 3.0l 204hp suspension is sport comfort sport+ normal please help
03-31-2021, 09:53 AM | #14 |
Rep 4
Hello guys its been a lot of time but im in the same position i want 235/50/18 because the roads in my country is really bad is there any problem with that size anyone with experience im worried about rubbing when the car is loaded with 5 people or vibrations with high speed. Please someone can help
03-31-2021, 10:01 AM | #15 |
Rep 4
235/50/18 BMW F10 525d will it fit 235/50/18
Hello guys im about to buy summer set but i want 235/50/18 because the roads in my country is bad is there any problems with that size rubbing when car is fully loaded or some vibration with high speed any problems. Is there any of you who is driving with that size please share your expirience
03-31-2021, 10:04 AM | #16 | |
Rep 33
03-31-2021, 10:08 AM | #17 |
Rep 4
Thanks man im gonna order some hankook 235/50/18 im happy to hear there is no problem because i heard a lot of thinks and i was worried but now i can order the tires i hole the comfort will be little better than 245/45/18
04-11-2021, 01:53 PM | #20 |
Rep 29,202
If they're OEM M6 wheels, they're 19x8.5 et12 and 19x9.5 et17. Too aggressive for the f10, especially in the rear.
04-12-2021, 07:29 AM | #21 |
Rep 1
widest rear tyre
recently purchased a f10 5 series m sport ,
currently running 275/35/r19 rear, 245/40/r19 on 351m alloys would 285/40/19 and 255/45/19 be an issue? tried to find on other posts but dont seem to be able to. |
04-12-2021, 12:29 PM | #22 |
Rep 4
2011 550i xdrive wheel fitting
remmib, new wheels are 9 et 6 & 9.5 et 28 based on part number. This is for an xdrive currently running 245ZR40 19x9 front & rear. Would going to 245zr40 in the front and 275zr35 on rear work? Don't want to mess up the xdrive. Thanks for your help!
