01-27-2021, 12:36 PM | #1 |
Rep 204
20 inch wheel help
Alright wheel pros, looking for some guidance. Thinking of picking up a staggered set of 20" 648m. I know the bolt patterns are different, but was wondering if anyone has managed to put them on using an adapter? I've seen quite a few adapters online. I have a 16 535 m sport with the OEM 19s on now.
648m Wheel specs F: 8.5in wide; 25mm offset R: 10in wide; 41mm offset Based off these specs it appears I'll lose 10 mm of internal clearance on the rear but the adapter should negate that (right?) Pic for reference |
01-27-2021, 12:52 PM | #2 |
Rep 1,356
It is possible but the wheels will be pushed out a little to fit the adaptor just like wheel spacers do. If you ended up doing it, I do have one front and one rear of these wheels in my basement if you need it.
01-27-2021, 12:54 PM | #3 |
Rep 204
01-28-2021, 02:02 PM | #6 |
Rep 2,591
I'm not really a fitment guy, I just have some random experience
remmib is the man you want
2015 BMW 535xi
01-28-2021, 03:14 PM | #7 |
Rep 14,522
remmib is the guy who can answer this lol!
01-28-2021, 05:27 PM | #8 |
Rep 29,202
Assuming those adapters are at least 15mm, you end up with a fitment of et10 and et26. And that's too low for a normal flush fitment I'd say.
Blue Angel997.50 |
