12-05-2022, 07:53 PM | #1 |
Rep 4
BMW F10 528i 2012 N20
Hi Friends, I am new here. I need help, I have one BMW 528i F10 year 2012. It is a excellent car. I have one problem: the trunk doesn't open (with the trunk buttom and the Keycontrol), not open. I had to remove the rear seat and open with the emergency handle, then, I was cheking all rear fuses, all are good. So what can be the problem?
12-05-2022, 09:49 PM | #2 | |
Rep 2,993
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
Mgretallack1.50 |
12-06-2022, 09:40 PM | #3 |
Rep 332
Drives: F10 535i xDrive, F25 xDrive35i
I would start simple and make sure the vallet switch in the center console is not activated.
StradaRedlands4933.00 |
12-07-2022, 07:42 AM | #5 |
Rep 7,475
What is it? Do you mean the VALET switch? If yes, open the owners manual built into iDrive (or the paperback owners manual) and do a keyword search for LOCKING SEPARATELY or VALET. It should explain the switch and give the location of the switch for your 5 series model.
The valet switch allows you to lock items in the trunk and restrict access to it if you are using valet parking or turning your remote over to someone. I don't know where it is on the 5 series, but on my 6 series & X5...the switch is located in the center console. On some models it may be in the glovebox. Where ever it is located...it is usually in a locked storage location where you use the metal keyblade stored in the remote fob to lock that area. Again, if valet parking and you want to keep items safe from theft...you set the valet switch, then lock the compartment with the key. This way no one with the remote fob has acccess to the storage compartment where the switch is located...and the trunk can't be opened. EDIT: below is the info from my f06 owners manual...yours should be similar:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 12-07-2022 at 07:49 AM.. |
12-07-2022, 09:53 AM | #6 |
Rep 4
Thank you!!! Is Working, The Vallet switch was in safe position..
12-07-2022, 10:15 PM | #7 |
Rep 2,993
Brilliant Houranimd49 !!!!
Houranimd49252.00 |
